Quality Wheel Spacers?
I have the spidertrax 1.25" spacers on mine. Stance is perfect in my opinion and nobody makes a better wheel than Toyota. I have had them on my truck for about 2500 miles and have had zero issues.
Interesting they say right in the instructions NOT to use an impact on them. I restore cars professionally and have been wrenching for 30 years. I used to think an impact was the way to install wheels... Nope. It's SO inconsistent even with torque sticks. One can be 150 LBS and the next is 40. I haven't broken a stud or worse yet lost a wheel (has happened to me twice) since I started religiously using a torque wrench about 20 years ago.
As for the wheel bearing wear... It'll be non issue. Sure put another 25 pounds a corner with cheap wide heavy aftermarket wheels and chunky heavy tires and you may notice a difference. But just a slight offset change isn't a big deal. I've had 3 second gen tacomas with a very similar hub/bearing design. All of them needed front bearings pretty much like clockwork every 75-80k miles. Two were stock and one was lifted with zero offset 16x8's and 33" tires.
Follow the instructions. Use loctite (which they actually come with) and a torque wrench and you will have no issues.
Proper torque without stretching the stud is all that you have to do! Breakage is from stretching the stud, plain and simple. Sneak up by torquing to 45 then run them again to 82-85 and call it good IMO.
bobdjr41
