Question about DIY Body Lift with weld-on sliders
did you end up installing the BL yet? whered you jack up the car at?
No not yet, I had a ton of stuff I was doing, did install factory extended rear brake line, urethane rack bushing, modified tjm bumper and modified my exhaust, hopefully this next weekend I will get to the body lift done, has to be done before my addicted offroad bumper gets here.
Hey [MENTION=84223]JustSomeName[/MENTION], did you ever figure this out? Did you end up remounting the sliders?
I did not remount the sliders, but I did get some help on the install. I have a friend that runs an auto shop and just put the car on an alignment rack. It made the install (relatively) easy.
Can't imagine I would've been able to successfully install at home with just a couple floor jacks...
So I'm about to get a 1inch body lift and am debating whether or not I want to DIY this at home with a couple of friends.
The Toyota120 DIY seems to be the most detailed and recommended DIY out there for a body lift
4Crawler Body Lift
In the DIY thread, when they're talking about lifting the chassis off of the frame...
So I have weld on sliders and I was wondering if anyone out there installed a body lift had weld-on sliders on their car at the time of the body lift install? And if so, where did you lift the chassis at?
I did that. It wasn't so bad. I just used a couple floor jacks and put some 4x4 wood between the sliders up to a 2x4 that contacted the body. Not really a big deal, honestly. You could probably just use some scrap wood and find something to go through the slider holes to give a place to lift the body.
