I have a 1997 toyota 4runner with manual transmission, 4cyl, and about 212k miles.
I recently noticed some rusty powder on my coolant reserve container and decided to replace the radiator and do a coolant flush of the system. What is the best way to flush it out? I've seen people do this 2 ways. One way is to take the petcock off the radiator and run hosewater through it until the heater core opens and the water runs clear. I tried this method and can get the water looking crystal clear. However, another way i've seen radiators getting flushed is to close off the petcock on the radiator and fill it up with clear hose water, run for 10 mins and then drain. I've tried this dozens of times and the water always runs out looking orangish from the built up corrosion in the system. My question is, will i ever be able to see the water flow out clear after running it this second way with the petcock closed? I am trying the prestone super flush and hope that fixes it up by driving around for 3 days with the solution in the radiator. Here is a link to the pics of the corrosion:
http://www.toyota-4runner.org/3rd-gen-t4rs/165649-corrosion-coolant-reservoir.html#post1664767
2nd question i had was I am aware that this may have resulted in a "pink milkshake" in my transmission fluid. How do you check the transmission fluid on a manaual 4runner? there is no dipstick under the hood. Thanks!
