ARK_SWAMP_RIDER
Looks good! I believe I'm gonna go the same route when my XREAS fails, just waiting for it to happen.
I have front springs and 4 tokico shocks I bought off a member here and don't need anymore. I was told it came off an '08 FJ with 10K miles on them. I paid $75+ship. You can have them for $50+shipping. Let me know if you're interested and I can get you a quote.
Great posts everyone. Im a noob and about to embark on the same project. Just want to make sure i have my specs straight. Im in a 05 4runner sport v8 2wd. About to hit 100K and the xreas is done. Been searching for 2 days and this is the best discussion I have been able to find (actually stayed on the topic)
Im going to do the fj springs and bilstein 5100's. SO can you help me with the following?
Springs from 07-08 fj cruiser (any other years work?) I think anything from 07-09 will work. There was a post on here about the '10 FJ springs being a little different and my need some modifaction to work. I never read what the outcome was, do a search and you might be able to find it.
Since Im in 2wd do the springs need to be from a 2wd FJ? Go with the 4WD springs, they will give a little more lift than the 2WD's from what I read.
Should i do springs/shocks on all 4 or just the front springs/struts and shocks only on rear? Replace all 4 springs and shocks.
The front are specified to be Drive/Passenger side, correct? Yes, green/yellow=driver side, green/grey=passenger
i dont need any spacers if Im not wanting much of a lift? No spacers (just fj springs on all 4) and setting 5100 on .85" lift. Same .85 setting for front and back? No spacer needed. Set fronts to .85", second notch up from the bottom. Rears are not adjustable, they will extend 2" more than stock
With the 5100's do you need a spacer to gain more lift or can you just adjust them? Or is there a certain point where you need a spacer? You adjust the amount of lift by moving the spring perch up or down. There is a metal ring that you put in a groove (based on how much lift you want) and the spring perch sits over that. I believe you can go up to 2" on the fronts. You could add a spacer if you like, but I don't think its worth it. You will be nose high above the .85" setting without getting longer rear springs.
Am I missing anything else? Beer and pizza if you find someone to help you with the install!! :beer:
Sorry if Im going over tha same stuff just trying to be informed for when I order and take to a shop or find someone in dallas to help install :cowboy:
Much thanks for your help!!
Def want to do the tires shortly after. Any thought on what sizes are good? Im currently on 265/65/17. I know if you hit a certain point there will be tire rub (from what I understand you can put a wheel spacer on but not sure if there are any negatives to that - going to do some research) Was looking at the Falken Rocky Mountain or Nitto grabber/grappler
Front
BE5-C475-H0
Rear
BE5-E703-H0
FYI I paid $320 shipped for mine.
I've just got 1.5" in the front and they clear, but barely. I moved the fender liner forward for safe measure, takes all of five minutes to do both sides. I've not been of road much though. CJ3Flyr haas a thread on them where several commented on the size. I'm posting from my phone so I can't post the link, you should be able to find it through a search though.
