Rushthezeppelin
I bought my truck about a month ago without an owners manual and with part of the visor card missing and I want to make sure I have the details of how to operate it and just overall how it operates. It's pretty clear on the card how you shift into 4lo but going from 2hi to 4hi can I just throw the J shifter down while moving? If so what's the max speed? Do I need to push in the clutch while doing so? Do I need to be in Neutral even while doing so? I've been playing it probably too safe so far and only shifting into 4hi the same way as 4lo.
My other question is how exactly does this particular setup work. Is 4hi open in the center and 4lo locked in the center (no center diff lock button on the dash with mine). Or is it always locked or always open no matter if in hi or lo? If it's open in hi does this essentially act like the awd button on the MM Tcases? Also is this system purely mechanical or actuated either electronically or with vacuum?
Just want to make sure I'm all squared away on these details with white stuff hitting the ground right now.
