Quick measurement request...
Granth77
Could someone with a stock 2014-2015 Trail please measure from the ground to the bottom of the rear wheel opening (centered above the wheel) and do the same for the front? I put in Air Lift bags this weekend and noticed the rear is higher than before, but not sure how much higher (I'm currently running 10 psi in the bags). Just trying to figure out the setting for my front 5100's when I install them.
Thanks!
Grant
Thanks!
Grant
From center of hub not the ground just incase we have different tires:
http://www.toyota-4runner.org/5th-g...t-height-measurements-needed.html#post1950325
RR = 36 7/8"
RF = 34 1/8"
LR = 36 1/8"
LF = 34"
Stock 2015 TEP w/kdss on stock dunlop's with ~7,000 miles. Garage tilts slightly left for the drain but I think it has the dreaded lean.
Thanks to both of you. It appears it increased the height by about 5/8 to 3/4". Given that increase, and the natural factory rake, I guess I'll set the Bilsteins at the 1.75 mark. Thanks again!
Grant
1.750 sounds about right for you. I'm about to install billies in the front @.850 to level out the TE which measures similar to the TEP.
RR = 36 7/8"
RF = 34 1/8"
LR = 36 1/8"
LF = 34"
What psi? Remaining tread left? Measurement from hub makes more sense
Wow! [MENTION=104049]marshal[/MENTION] [MENTION=92049]LandCruiser[/MENTION] [MENTION=128287]DAGNABIT[/MENTION] must all be sleeping in today.
RR = 36 7/8"
RF = 34 1/8"
LR = 36 1/8"
LF = 34"
Put keys in turn ignition on... back out of garage..... drive to flat area, remeasure
TerryNap61
