RedKnuckles
Leave It In, Or Take It Out?
Just checked the stock ride heights, and found the rear to be roughly 2.25" higher than the front. If the 2:1 ratio is accurate for the effect of adding a front top out spacer, the 1.125" spacer will make it perfectly level. This will be fine initially, but I am concerned that the rear will sag in the future. Unless it is detrimental to the system, I would prefer to leave out the stock soft rubber spacer to reduce the gain in height. It appears to me that the stock spacer is indeed in the preload position. Leave it in, or take it out?
