mtbtim
Elite Member
So I picked up some Shell Rotella ELC, hopefully this is the right coolant.
Poured in a gallon and the radiator was full, but lo and behold there is a pretty significant leak. The leak seems to be on the transmission return though, which I thought was transmission fluid. Is something wrong with my radiator?
Both fluids are red, but I'm pretty sure it's coolant leaking, it's very thin.
Yep, sounds like the petcock valve drain on the bottom of the new radiator wasn't tight. If it started leaking as soon as you put the coolant in, it's probably coolant. The only way the trans fluid will mix with the coolant is if the new trans cooler in the new radiator has a crack in it. If the engine wasn't running when you noticed the leak, it's probably the coolant leaking. But, get under the rig and look to be sure. The trans cooler connection closest to the radiator petcock valve is the the send line connection coming from the trans. You should be able to easily see where the leak is coming from as long as your skid pan is out of the way.
