Radio diagram for 2006 v8 runner
1MZ-V8
Hello,
My truck got broken into and they stole my Eclipse AVN 6620, my oem harness got cut. I just finished installing the OEM 6 Disc CD Changer unit, everything is working except for the control on the steering wheel. Can someone provide me the diagram for those wires?
the dimmer on the radio is also not working. any help will be appreciated.
I am pretty sure i am missing a connector somewhere, so far i only have two connected to the radio plus the antenna. btw: I happen to have an extra set of eclipse harness they seem to be very similar to the oem but i know for sure its not 100% the same.
The problem I have is that since my harness got cut off, I need to identify each wire. I cannot tell which pin is which wire since its all cover up.
The local stores does not sell these connectors, they only carry the one for people to switch to aftermarket unit harness. :(
My only choice is either junk yard or dealer (which cost $2000+ and take the whole front dash out. its a waste of time and money) :(
Does anyone know if this will work?
Select Toyota 1986-2010 Models.
For the complete list of compatible vehicles, see the compatibility tab above.
Does not work with amplified vehicles. Does not work with vehicles that have JBL.
Trying to reinstall your factory radio? Were the wires cut? Then you need this harness. It plugs into the back of the factory radio. Our harness meets EIA color codes to take out the guess work out of what wire does what.
Factory Radio OEM Reverse Male Wire Wiring Harness 22 - eBay (item 390328841271 end time Aug-04-11 12:52:04 PDT)
turbomikee
