Rain from Overhead Console
robb600
After heavy rain last night got in my truck this morning and had water all over the center console and as I started driving had water leak and drip from the overhead console. Any one ever experience this or have any idea where the water could be getting in?
I assume this is the first time this has happened? Had your sun roof open lately? If so, did you close it ALL the way?
I guess there are some sort of drain channels for that area that could be plugged.
Someone with more knowledge will chime in soon.
Its unfortunately happened before but was enough this morning to try and look for a solution. I've run weedwhacker line down all the drains and theyre clear. Also ran a garden hose test on the sunroof and its sealed.
Had your windshield replaced? Check the seals around it and see if you can find anything that looks suspect. And there are four sunroof drains, did you snake them all?
AndiGarage
