raKnizek's 2000 SR5 Maintenance and Build
I applied some rubber flare trim to give a more finished look to the SR5 flare. Easy to work and very happy with the result.
I used this which was less than half the cost of using the Toyota trim from the Tacoma which a few guys have done. This was recommended by [MENTION=116195]weekendclimber[/MENTION];
I really do think the trim finishes the flares good. Nice rig BTW! Peanut butter and jelly of the 5 speed!
Kick Plate Screws
Shot these with some paint while I was painting the wheels on another project. They were pretty ratty looking and I remember someone else doing that here
Thanks for posting that up. I have gone through a fiasco with searching and ordering the rubber trim from Toyota. I have ended up with different colors. I'll give this a try even though I have the wider flares.
The truck looks great. I dig the color you painted the LC80 wheels. I just purchased my first polisher. You give me inspiration :thumb3:
The factory color on those screws is a dark green/black color. Silver is better than weird and oxidized like they get though!
-Charlie
Let us know how it goes! GOod luck with the polisher. Patience is key
Wow, looks great! I replaced my sill plate screws with Stainless from Lowes. No more rusty looking crap! I went one size larger because the old ones weren't grabbing the plastic clips anymore & my new rug was pushing the plate up. annoying!
Thanks! I will have to keep this in mind. There are a few that are not all that snug anymore.
I am planning to get rid of the chrome this winter. Thinking body matched grille and then matching the bumper chrome to the wheels (powdercoat). Picked up the older grille for cheap just to test the look. I would keep this one but some of the mounts are broken and the paint is pretty bad. Will likely have my stock grille refinished
2nd attempt at interior LEDs
Redid my interior dash lighting. I went with green the first time but was never that happy w the result. The bulbs were much too bright and there were a few that didnt fit right.
Decided to go w the amber look. I think its easier on the eyes at night and also gives it a nice period correct look. Was tempted to go with the white though.
I ordered bulbs from SuperBrightLEDs this time around and overall the quality is good but I now have a different set of issues.
- Fairly happy with the gauge LEDs. Appropriate brightness but some hot spots. Good color.
- Rear window switch, rear defrost, and key ring came out perfectly.
- Climate controls are the most disappointing. These bulbs have a single forward facing LED and its not so great here. My previous bulbs had side facing LEDs and it was much better.
- Ash tray LED is way too weak to shine through the green lens that is in the tray
End result:
Contrast of the redline is lost a bit but thats going to be the case unless you go white (or maybe some other incandescent bulb).
Went with warm white LEDs so for the climate so I wouldnt lose the climate temp colors. Good color/brightness but very poor distribution (looks worse in person than in the picture)
Key ring
Previous for ref:
Full brightness (shield your eyes!)
I used to leave the ash tray out so that the light illuminated the shifter area. Will probably add a small light somewhere else to fill that role.
Center Console Cover
Been a long time coming. Decided to finally have a go a recovering my center console arm rest.
This is the cover I used
I am no expert but for the price this was a great find if you're willing to put in a little effort.
I also used some foam I had from my sound deadening project (more to come on that), a staple gun, and some 3M spray adhesive.
Here is what my cover looked like to start.
If you have a leather covered lid, you will find a layer of fairly firm padding under the leather
I have a spare lid. I forget the year it came from but it is not leather covered. Interestingly the structure of the plastic piece is actually different. Who knew...
Next I covered it with a layer of sound deadening foam. This most likely not the best choice but I already had it available and I don't expect it to go flat too quickly. I just wanted a little refresh of the padding
Stretching the cover over the plastic/foam. I used a little bit of adhesive and then stapled around the edges. This is how the original is attached as well. The extra foam layer made this more challenging but I managed to get enough material around to effectively staple it.
Screw the inner panel back together. I used a plastic wedge to push and extra material under the plastic as I was screwing it down
Job done! As you can see the stitch pattern is not the same but I think it looks great. Sure an original replacement (or professional job) would be nice but for ~$35 is was a nice project.
Sound Deadening
Sound Deadening
I finally decided to tackle the sound deadening project I have been wanting to do for a while now. I have had this goal in mind of making my 4Runner as capable off-road as possible while still being comfortable for me and any passengers. I imagine the comfort and luxury of a Range Rover with the capability and reliability of a 3rd gen 4Runner. Of course there are many things that will keep a 3rd gen from being a true “luxury” vehicle but it is good to have a goal.
My measure for success with this project was first, to reduce as much of the mud tire noise as possible and second, be able to cruise at highway speeds and not have to either crank the stereo to hear it or yell at my passengers to have a conversation. For me, interior noise level is a huge factor in what makes a luxury vehicle.
I have never done anything like this before and have never worked with these materials before. If anyone is an expert, I am sure they will be able to see things that I did incorrectly. I used a combination of posts from other members here and various resources around the internet including Raam Audio’s How To Guide (How-To)
Before I get into the details I will start by expressing how much time and effort this took. I knew it would be a large undertaking but damn… I worked on this for a few weeks, mostly on the weekends. If you are down on patience this might not be the best project for you. I think I am right on the edge of being able to withstand the tediousness of this job.
After a decent amount of research I decided to use raamaudio products. Certainly not the cheapest option but (without any comparison) it seems like a great product. The peel and stick application was great. I ended up ordering both package #1 and #2. Probably overkill for someone who knows how to do this more efficiently. It seemed like I was struggling to use all the sound deadener and had to stretch the foam. I also decided to go all out and get a roll of MLV (mass loaded vinyl) as well off Amazon.
The order of application is:
1. BXT Sound deadener (this is your Dynamat, or similar). This stuff reduces the amount of resonance in panels but does not actually absorb sound. Its mainly for the lower frequency sounds. You don’t actually have to have 100% coverage here. 60% or so is sufficient.
2. Closed cell foam. This is goes over top the deadener and absorbs the higher frequency sounds. This is the majority of the sound absorption. Full coverage is ideal.
3. Mass loaded vinyl. This is an additional layer of sound absorption.
Out of the factory the 4Runner uses a combo of all three of these. I found small patches of sound deadener hear and there, lots of foam under the carpet, and some MLV in the front footwells and trunk area.
I started out with the driver door. In hindsight I might have started somewhere else. Getting the driver door correct is important as its closest to where you’re sitting. I decided early on that I wouldn’t not try to reuse the moisture barrier. The sound deadening material, when applied thoroughly, should take on this role
The metal behind the vapor barrier was pretty dirty so I cleaned the entire door with all-purpose cleaner followed with isopropyl alcohol
The doors were by far the hardest because of all the details you need to work around. You need to watch out for the door lock rods, latches, etc. The first material I put down was the BXT on the inner door panel. You can’t see the patch thats right behind the speaker. Placing BXT and foam behind the speaker should enhance sound quality.
Ideally you would get 100% coverage inside the door with the foam. I saw some people essentially ball it up and stuff it into every corner they could. That may be effective but I went for a cleaner install and made sure I had full sheets applied everywhere I could. Regardless, make sure you allow the door to still operate and keep the drain holes open on the bottom.
Once I had ~60% coverage with BXT and as close to 100% foam coverage as possible I started on the outside panel. I used the material to cover the large openings in the door. I carefully cut the plastic backing material so that behind each opening was not just a large flat sticky surface. The biggest downside to this method is serviceability. When (not if) a door component fails I will have to cut this away and reapply.
I kept anywhere from .5” to 1.0” clearance around each plastic clip that holds the door panel on. This was sufficient for most areas.
Here is the door fully covered with BXT. I tried to get as many large pieces as possible but I couldn’t avoid small patches in a lot of the areas. It helped to use a Sharpie to mark out the cuts ahead of time.
You will notice i cut holes around all the bolts so that they would remain visible. Another mistake I made on the first door was not leaving enough room for the interior door handle. the back side sits very close to the metal so you need to leave a square cutout for the entire handle. I also had to go back and change how much room I left for the door latch rod.
Finally, here is the door with the final layer of foam. notice the cutout for the door handle. I dint have too much trouble fitting the panel back on. It is pretty forgiving. There were some foam blocks on the back side from the factory that I either had to remove or move to a different spot.
Here are some pictures from the other doors. The rears were the same process.
This image shows how I used two big pieces of foam in the door that overlapped over the crash bar thats inside.
I removed the rest of the interior and started on the rear cargo area.
Picture taking started to slow down as the days invested in the project increased…
Here is the cargo area with all three layers applied. This was the easiest and quickest area of the entire project. The cargo area and doors will have the greatest impact.
Since reducing tire noise was a big objective I focused on the rear wheel wells pretty heavily. You can see all three layers were applied. Again, I didn’t just stuff foam into the corners haphazardly but I tried to get 100% coverage within reason. The amount of space behind the panels is pretty forgiving here as well even with the larger storage bin on the later models. That being said, expect the panels to be at least somewhat more difficult to assemble.
Here is the left rear wheel well. I tried to get material in-between this opening and the rear door as best as possible. The gas filler is in the way.
Another shot of the rear. I probably could have done more alone the B and C millers but It was getting very tedious at this point… I did add MLV on top of the wheel wells after this picture was taken.
This is the rear seatbelt area
I moved on to the rear floor next. I applied BXT and foam to most of the rear floor under the seats but did not put any MLV.
As I mentioned, I feel like I had a lot of BXT to spare so I ended up with almost 100% coverage on the floor. Unnecessary maybe but I cant imagine its doing any harm. 100% on the foam as well.
Here are some shots of the front floor. I also focused on the trans tunnel. Be careful building too much material up in this area. It will make the center console difficult to reassemble. I has to remove most of the material from under the cup holders because it just wouldn’t go down far enough to clip in. I also tried to peel back the existing material on the firewall and place even more here. Just make sure you leave room for the pedals to function properly.
Driver side:
Passenger side:
Lastly, I decided to place a little foam on the back side of some of the interior trim pieces. This is the outside driver/passenger foot well trim
B-Piller trim
Lastly, I had a few squares of foam at the end so I put them under the shift boot.
All in this project was a pretty big pain. That being said I think it was worth the challenge. I think I eliminated most exterior noise coming into the cabin with the exception of wind noise and unfortunately a good amount of the tire noise. The wind noise is expected due to the inefficient shape of the truck. Cant change that or the fact that we have single pane windows. The tire noise is significantly reduced but mud tires really just make a shit ton of noise, especially as the wear increases. If I had highway tires or even All-Terrains I bet there would be hardly any noise. You can really tell the difference when looking to music or having a conversation. Just opening a window at a stop lights makes you realize how much more sound is kept out. The truck also just feels even more solid than it already did. The deep thud of the doors closing to the reduced crashing over bumps (even with a lift and tires) I am putting this project into the “mostly successful” column. Thanks for reading.
Skid Plates #1
Purchased a BudBuilt front skid, DIY belly pan skid, and Lotus RLCA skids from a local owner who was parting out his truck.
Ditch Light Brackets
These came with the Skid Plates so I threw them on. Don't have lights mounted yet but I am thinking round looks better than square.
Door Trim
I (re)added some black trim to the doors. When I purchased the truck it had these installed but I initially removed them. Unfortunately the paint underneath suffered. After a few years of looking at the artifacts of the old trim I decided it is better to have it on and cover the damaged paint. It may not be the cleanest look but I actually do not mind it. There is some practical use too as it will protect the doors to some degree.
I had to find a flat black universal product and cut it to fit. Took a few attempts to get a result I was happy with.
Hood/Fender adjustment
The front driver fender and hoodline have always been slightly misaligned. I took some time to mess with it and was able to raise the fender to match the door line and also close the hood gap. It is not 100% perfect but it is much improved.
Man you have done some nice work to the 3rd gen. What next on your list?
Thanks! Next project on the list is to finish the sleeping/storage platform that I started. After that I just want to get out and use it.
At first I wanted to go all-out with bumpers and gear but I think the "OEM-plus" look is more fitting to how I use it. Farther in the future I would like to get a rear locker and move to the 4:30 gears. That should be good to run 285's when paired with the 5-speed.
One thing I left out. I spent more time than Id like to admit trying to locate a 2000 driver side mirror in Desert Dune. This was difficult because the mirror was redesigned in '99, heated glass was added in '00 and this was also the last year for the Desert Dune color. A "rare" 1-year mirror for all you nerds for detail out there!
So it took a while to find the right configuration in good condition but my mirrors actually match now.
Deno91
