RallyArmor Mudflaps
Looks like a pretty killer deal if they do fit. What were you thinking for hardware and fastening points? I would be interested as well if someone can confirm a pretty good fit - the stock flaps don't seem do too much with 33's.
I will use the hardware that came out of the running boards and rear "flaps" most likely.
Hopefully someone on here has a set so we can see what they look like fitted up...
I made my own set out of 18 Wheeler flaps. I know not a 3rd gen. I can get better photos if needed.
All the others are garbage. I had a sti,outback xt,and a wrx all with rally armor urithane. The standerd you are better just buying some autozone flaps. Also they don't come with hardware
I dont need hardware and I dont wheel. Standard ones will be juuuuust fine.
Looks good. I got a 97, which doesn't have that lip on the bumpers or the around the fender. How do u thinm that will work ? Did u go off roading wirh them
It will work if there are no fender flares, I mounted to the metal body of the truck. They will likely have to stick out more and will look more like the Subaru guys run them. Also I woldn't recommend them if you have larger than 32" tires.
Good flaps!
I like your mud flaps as they really do its job.
How much total you spent for the 18 wheeler flaps for all 4 wheels?
Aren't they heavy?
The rally armor flaps are short and it won't even cover the front doors. If you plan to use these, you will need an extension from the bottom.
Hmmm got 33" ......
Aren't they heavy?
I think I spent $40 on them. I was able to cut four auto sized flaps out of two 24x36" rubber 18 Wheeler flaps. They are heavy, but they keep the shit off the body, and I think they will take a beating. I'll get the link to them when I get home.
