ramonortiz55 4runner build: La Venenosa
Picked up a transcooler to prevent the strawberry milkshake issue:
Ordered some misc maintenance parts from camelback Toyota:
^^^ Timing belt, Water pump, PCV valve and the mass airflow thing.
When I bought the ARB locker and compressor it didn't come with any air hose. Thanks to @07trd4x4 , I was able to get one in the mail today. :D
Today I had the sliders fit welded. hopefully tomorrow I get to paint them for the final install.
I also installed a transmission cooler.
I decided to do a write up for the transmission cooler.
Transcoolers are very important in 3rd generation 4runners to avoid the pink milkshake issue. (google it!)
I went ahead and bought the B&M 70268 transcooler.
Picked up a quart of transmission fluid, some hose clamps, and 3/8" inner diameter transmission hose from vatozone.
First step is to make sure the 4runner is cool. Don't want to get scalded by any hot transmission oil while removing the existing transmission hoses.
Next I removed the grille
The grill is held in place by five support clips. Each support clip looks like this (pictured already popped out):
If we look to the side of the support clip, well see its open. There is a little knub in there. This knub needs to be pushed back with a flathead screwdriver to disengage the support clip.
Next we go under the 4runner and remove the skid plate. It is being held in place by a few bolts:
Dropping skid plate:
This will expose the bottom of the radiator and the transmission hoses:
The driver's side transmission hose is the RETURN line.
The passenger side transmission hose is the SEND line.
Follow the hoses until you reach where they connect to hard transmission tubing. The transmission hoses are the ones with the sleeves in the picture below. I couldn't take a better picture because they are in a tight spot:
Next I mounted the transmission cooler, notice that I had to remove the drivers side horn and placed it on the same bolt that holds the drivers headlight. I decided to do this because I didn't want to obstruct wind flow across the transcooler:
I also went ahead and connected the hoses:
I attached the transcooler onto the radiator using supplied zip ties.
I ran the hoses thru an opening to the left of the radiator, it appears that some tubing runs thru there also.
After removing the existing radiator hoses, I attached the upper transcooler hose to the SEND tubing.
I attached the lower hose to the RETURN tubing. I made sure to not mix these two up.
So what happens to the exposed inlet and outlet at the bottom of the radiator?
I used some leftover transmission hose to connect them together.
If I ever need to use the radiator in an emergency, I can always connect back to it.
So when I installed my aftermarket radio, I noticed a loss of AM signal on my radio. YES, I listen to AM radio. So shut it!
After doing some research, it came to find out that the 4runner has TWO antennas. One for FM, and a booster for AM that runs towards the back.
Other's say that the booster in the back is for FM also. Regardless, I wanted to use that "booster" antenna to improve my AM reception.
Since the aftermarket headunit only had connection for ONE antenna, I had to find some sort of adapter to go from two antennas, two one antenna.
After doing some research I found a Y adapter, and an scosche adapter for the smaller antenna plug:
On amazon theyre found via:
Metra 40-UV43 Male to Female Motorola Antenna Cable
Scosche Mda-B Micro/Delco Antenna Adapter Tip
I took my headunit out. I am not going to go thru those steps since I already discussed it earlier in this thread.
Once I pulled out the headunit, I dug around for the two antenna cables:
The smaller one is for the rear antenna. The larger one is for the regular whip antenna that I was using to plug behind the headunit. The smaller antenna uses the scosche adapter before plugging it into the Y adapter.
I then plugged the Y adapter into the back of the headunit.
Voila! AM reception is now improved!
Savage offroad bumper came in yesterday:
I also got some nice switches from OTTRATW, thanks to @geekhouse23 in helping me understand how these work.
the switches will go here:
final coat on my sliders:
primed savage bumper:
installed hood struts:
installed switches and rain wiring for the switch accesories:
I had a leak out of my radiator develop a few weeks ago.
Replaced most of my cooling system:
Radiator, radiator hoses, thermostat.
Also had a little mishap with a rogue screwdriver. Pierced a hole in my condensor and lost all my freon. Had to install a new condensor.
Picked up some craigslist specials.
A used OEM CV axle with a torn boot for a rebuild project
A Carquest CV axle brand new in box
$50
I think the guy smokes weed.. his house smelled like reefer. The boxes stenched up my car on my way home.. :rasta:
Installed my savage offroad bumper.
Finally!
Ripped off the stock bumper:
Now that I had space to work with, I soldered the wiring for the turn lights:
Installed the bumper brackets to the frame:
Set the bumper in:
Rattled it in place:
Cut off the stock fog plugs and soldered them to the led pods:
Some glamour shots:
toyodajunkie
