Rear axle seal leak continues
CaptainGiggity
So my rear axle is still continuing to leak on my passenger's side after I went through the whole repair process the BigFish has written up on here. The driver's side is bone dry so I know it wasn't a fault on my part for reinstalling everything incorrectly, and i'm dreading the thought of taking into a shop only to tell me things I already know or going to buy all new parts just to have it start leaking on me again. I had been told but I'm unaware of the validity of it but since my 4runner was involved in a very minor front end collision I was told it may possibly a bent rear axle making it the reason why the side won't seal correctly. Any thoughts or ideas on what may be wrong?
Not sure how you could possibly bend a rear axle housing during a very minor front end collision? Check and see if your diff breather is all clogged up. I battled rear axle seals. I hate em.
Check and make sure the bearing is still good. If not, the axle might be wobbling enough preventing the oil seal from doing its job.
I'll have to take a look once I move but I don't have the luxury of time unfortunately so this may have to just leak in the mean time. But I had a bought brand new wheel bearings from the toyota dealership so I'm assuming they should still be good with less than 10,000 miles on it haha. But I planned on tearing it apart again when I get the chance so I'll take a look into the while I have it off. Thanks for the input though guys I appreciate it!
If the components are not pressed into exactly the correct position you can leak very easily. The thin lip on the factory seal leaves very little room for error.
goddesszilla
