Rear Bumper Build
Finished welding the gussets and notching them with the grinder. I also drilled through the rectangle tube and tacked the receiver and trusses on. I ran out of wire so this is all I got to tonight. I only have about a weeks worth of welding experience so don't give me too much hate on my welds. This beast is already ~85lbs! I'll post some photos of my side panel mock ups tomorrow when I have daylight.
I guess it is the welder and not the welder that matters :thumb3: To be honest I am using a welder from Harbor Freight.
Bumper looks like its going to stout for sure, good job.
As for the welds using a HF brand with limited experience under your belt they look pretty good,you should be proud
Thank you! I am very proud! I spent probably 3 months researching about welding before I ever even touched a welder. My project has slowed at the moment just out of lack of time currently. Hopefully the next week will pick back up. I have the side panel designed just no photos to show yet. I also got held up with another project because I got ticketed for not having mud flaps so I had to fab up a set of 'rock tamers' to pass police inspection.
Just purchased some mounts for D-rings and some red Smittybilt D-rings. Just waiting on the mail man...
I know the thread has gone quiet but I just started working on the bumper again. Here are the D-Ring tabs tacked on. I am waiting for my friend (the guy who has tools to cut the metal) to come back from his trip so I can get cranking on the side panels.
Finally got around to getting a photo of my side panel mock up. Haven't decided what angle I'm going to cut the wheel well out at yet but heres how its looking so far.
Its a little hard to visualize in white so here is a little rendering to help.
Any recommendations on tire carrier hinges? DIY ideas or cheap places to get them?
I know the double sheer is popular and fairly reasonable but I used heim joints and saved a good bit of money. Plenty sturdy for a joint and smooth as silk for turning. Just make sure you get joint wiper seals if you go this route. Your joints would probably need to be closer together or almost on top of each other but I like the adjustment the joints provide.
Bumper looks great man!!
I've seen both of those hinges and the only problem is the price! $80 for a hinge would be a large fraction of the overall cost.
You must be getting bored by now but I am on another pause because I recently just found a TRD Supercharger and an E-Locker that I might be purchasing. If this deal goes through the bumper build is going to be set back quite a while. I should find out this week if it is going to happen or not.
D'Angelo
