**Rear Coil Spring Discussion - The Perfect 3rd Gen Rear Spring**
Finally got the 4runner all loaded down the other day and was very disappointed. I am an avid mountain biker and 100% of the time have a 45lb bike rack hanging off the hitch. I went camping with a few buddies and between the gear in the car, 3 guys and 3 bikes + a thule pod on the roof, I was less than a quarter inch off the 5.25 durobumps extended bump stops. Made for a fun ride on the dirt roads back there. The previous owner told me it had OME 890s in the back.
What would you guys recommend for this load? I want something with 3" of lift max (preferably 2") that can handle the rack (45lbs) + 2 bikes (30lbs each) with my camping gear. I will mostly be using it loaded on highway driving and some pretty light dirt roads. Ideally I wouldn't be crazy lifted unloaded either, as it is my daily and I would like to do real wheeling without the crazy load. I've got some sort of bilstein Looks like the 210v would fit the bill but might leave me with crazy rake without a load. Maybe LC wraps? What do you guys think? An impossible ask?
Ome 906.
Haven’t seen anyone mention AC Delco. I just put in the 45H2131. They’re cheap and lifted my sagging rear end about 1.5”. Now the rear sits about .5” higher than the front, which I’m guessing have the stock ‘98 springs. Ride is good, the progressive rate probably helps that.
I still don’t understand.. I got some dobinson 210v coils this last summer and threw them in for a day. I sat at 5.5” of lift with a 4X innovations real bumper w/swing out and spare (Also 50lbs of daily tools/gear in the back). I feel like that’s on par or more than people with stock weight are getting. I double checked the box and it did say 210V but it just feels like I got some 220v coils lol
I don't do much off-road stuff, I use mine more as a "truck" for hauling. I don't need a lift, I just need it to be a comfortable ride with the capability of towing a fairly large trailer. I have considered installing airbags in the springs. What do you guys think of this?
Did you keep the inner bumps with the 210v's? I took mine out (mainly because I couldn't get it work with the spring compressors I rented, lol) and I'm sitting at 39" floor-to-fender with about 150-200 lbs. of extra weight between the cargo area and roof rack.
This thread was originally started for people looking for a lift spring that can support 200+ lbs of gear. Your ACDelco springs aren't going to come close to that. The ACDelco springs didn't even lift the rear of yours enough to bring it back to the factory amount of rake in the rear with the vehicle unloaded.
If you are satisfied with your current unloaded ride then airbags will be the best solution for your towing/hauling needs. If you can handle a stiffer unloaded ride then OME 906's would be a good choice.
No the inner bump stops left when I put the 891’s on a while back. My stance with 891’s is great until I load up and hit the trail with the family. The sag drives me nuts! Not sure if the lc 8 wraps would correctly fit the bill either. Or air bags I guess.
Interesting! I know it took about a week for my 210v's to settle down a bit. I'm at about 4.25" of lift now.
What's your rear hub to fender measurement?
I installed FJ Cruiser coils on my 3rd gen 4runner, primarily to fix saggy rear end.
I used the 3rd gen 5100's and added one 10mm OME trim packer to each side. It sits at 21.25 hub to fender on drivers side, and 21.75 passenger side. This is with 75-100 pounds of gear/tools in the cargo area. When the kids are with me it doesnt sag more. I believe the FJ Coils handle extra weight pretty well.
The ride is outstanding in terms of comfort. Sometimes I wish it was an inch or so higher, but I've had no issues and I run a 32" tire that looks great with the mild lift.
Haven't really wheeled with it, but travel on some hunting trails very comfortably, and with confidence. During install I was concerned about the coil seating, but there have been no issues. Just a larger diameter coil. The coil was about an inch shorter than the factory coil, and has a larger wire diameter as well.
I also replaced the front with FJ Coils set on second perch. If I would have set on bottom perch the rear would have more rake and I'd be happier. It sits perfectly level currently.
Hopefully this clarified the use of these coils for some people. If you are looking for a mild lift 1.5 to 2" or so, it's good to go. And the coils only cost me 100 bucks off craigslist.
on the front, do you think that would handle the extra weight of a plate bumper and winch adn not sag and still allow the 265/75/16 ( basically adding 150 pounds)
I don't know to be honest. I have a cheap brush guard that the previous owner installed on there, and I added LED pods to it. Those don't weigh a lot, so not a great comparison.
I think the FJ coils handle weight better than 4runner coils though. I wouldn't rub if it was on the lowest perch, which I believe is an inch or so lower than where it sits now. So in theory, as long as your added weight doesn't sag the front more than an inch you would probably be ok, with the FJ coils on the second perch.
Hope that helps. I'll try to get a hub to fender measurement on the front for you by the weekend.
The best option for your truck is the Dobinsons 137v. It is a triple rate spring and can handle the widest variety of load (170-240-320LBF/IN). Around town they are a bit firmer than stock, but paired with the right shock not overly jarring. When loaded with four adults, camping gear, rear cargo carrier with 200lbs on it they settled maybe .5in. Unloaded i netted ~2.25in of lift, and used a 10mm trim packer over both to make it an even 2in when fully loaded.
They will ride softer unloaded than the OME 906 [220lbf/n] and fully loaded take a lot more weight.
The one thing you can't do with these springs is run extended shocks...the coils literally fall out with the Tokico LC shocks in place. That is why I ended up going to the 210v.
Is anyone familiar with Dobinsons C59-131 and C59-297V? These are rear coil springs for the Prado 95 with 40mm lift. C59-131 is constant rate while C59-297V is variable rate. Unfortunately, I do not have info with regards the wire diameters, spring rates, and free heights of these coils.
It’s doable. Did it in a friends: 33s open/locked some jerry cans and a hi-lift. Of course bumpers plates and sliders too. Started 7am on the south sat morning and off Sunday afternoon.
Its doable, My buddy locally did it in a 5thgen 4runner on 33s. Just nicer to wheel a sas lol. I hate trail repairs when I can wheeled my built crawler and walk it
Do you know if the TRD model uses the same springs as the non TRD models? I might hit the LKQ to pull a set if they’re the same.
My spring experience
OME906: provided a good lift for what I wanted initially. However the rate was way to rough for my liking. I wanted something as soft or close to stock, But this was way to much. Tried revalving my shocks to try and work with these springs but I just could not get the ride how I wanted.
LC8 wraps: Now these felt AMAZING, since they are about the same rate as stock just significantly larger. I loved the ride and flex, My only issue was how high it was riding in the rear. So it was the opposite experience as with the OME906. I debating cutting a coil off to bring it down , but I figured someone else would like the springs. So I sought out to find something a little shorter.
“GX springs”: Now I used a prototype spring that I got from work that was supposed to be a close copy to the GX470. Free height of 16.570” and a rate of 196lbs/in. These brought my ride height a little lower and gave a rougher ride. I used these the longest as I revalved my shocks to make these bearable to me. It was good but I still was not fully satisfied so I went to find more springs to try.
Jeep JL front springs: I went to offer up to find a cheap set of 2020 JL front springs. I found some for $30 so I took the opportunity to try it. So these fit up nice except I could not use the coil bump cone. So that kinda sucked, As for a lift, it brought my ride height significantly lower. A bit too low for me. But I drove around and I must say the ride quality was VERY nice. They are a 115lb rate. So that’s why it was so soft. HOWEVER I was hitting my bumpstops non stop. I can stiffen up my shocks so it wont compress as easily but whats the point of that. It would be perfect if it was a bit heavier. And as I stand I just have a drawer system in the back with not much in it. I do not think these coils will do well with a rear bumper as I will be making at some point. SO now I think I am going to circle back to the LC80 springs and try a 7.5 wrap.
The spring hunt continues…
delislerebecca
