Rear end hop off road
Drunner97
Rear end clunk/hop
That's the best I can explain it. I was out playing yesterday and for the most part everything was smooth sailing. No noises, suspension felt fine, but any time I hit a pot hole where the rear end would drop and hit suddenly, it was like it was jumping back up hard and kind of felt like it was hopping. I can hit speed bumps and dips at 30-40mph and it doesn't make a sound. Is it possible that the rear sway bar is binding if one side falls into the pot hole and the other doesn't? I did shove a 1.5" daystar spacer in on the driver side and lifting by the rear diff I wasn't able to get the sway bar links in both sides. Driver side was lower so I had to lift that side solo to get the link back in.
On another note, I did extend the driver side link about a 1/4" this morning, and if I lift one tire off the ground, there's about a foot of clearance before the other side starts to lift. I also searched around and didn't really find anything similar to my problem.
MaximussK
