Rear Hatch Hydraulic Arms
xhimsa12x
Okay, So I think I need to replace these Hydraulic arms on the back hatch cause they seem to be struggling when lifting the hatch and holding them all the way up. I may also need to replace the hinges at the top as well. I'm a little OCD about some things and every time I lift it, it Groans a little which is incredibly annoying!!
Forgot to post my question.
Are there specific ones I need to buy?? like certain extension legnth and so on??
look up lift gate struts, or liftgate shocks, or monroe liftgate, or sachs, or a plethora of other search threads. or even amazon
<year> 4runner liftgate shocks.
Find a junkyard for used replacement ones off a 2001-2002 4runner. They should run about $10 for the pair. They are made by KYB FYI.
If your pockets are deep, you can get new ones for $250 a pair with online dealer pricing.
All aftermarket ones don't have enough a#$ IMHO to keep the rear as high as it is supposed to be.
I bought two struts from Amazon, StrongArm # 4286. They're like $25 a piece. They work awesome. Once I pull the hatch open, it pushes itself to full extension, which was higher than my worn out OE ones ever did.
Awesome - I have to do this because I keep hitting my damn head on the not-fully-extended hatch! :frusty:
Awsome Thank you for the advice. The main thing I was worrying about is buying to cheap A$$ ones from autozone or something and then not having enough pressure to lift it properly. I would be pissed!!!!
But if you want the mounting brackets (hinges), then you have to go OEM. And they are only sold as part of the strut assembly
If by some miracle you have broken the mounts off, I'd get those at a wrecker for sure. $250 for hatch struts is :der: IMO.
now i saw the ones on parts geek though, i would go with those, i bought one monroe replacement one for my wifes yukon and it was super strong that I only replaced the one.
In all this, I'm amazed that no one has posted the specs. For the rear hatch lift struts.
Compressed Length:
Extended Length:
Weight Rating:
End Fitting Size & Type:
I've tried going to different suppliers here( NAPA, OReilly, Autozone,...) and none of them have the right ones. And no wrecking yards here have 4Runners for some reason, there's plenty of 4Runners on the road though. But since I just have to duck and my wife has no issues with it(read: she's 4'11) it's not a big deal.
mine do not like the cold. during the day my hatch stays up just fine, but in the morning it falls on me occasionally.
2001ATL
