Rear LCA bolt
Androo
Hey everyone,
My rear LCA bolt is stripped and just spins freely. I haven’t had time to pull the other side out but figure I need to buy a new bolt regardless. My question is I can’t seem to find a part number or anything about that particular bolt. Does anyone know of a part number or what type/dimensions it is? It’s not a “special” bolt like a cam bolt correct?
TIA!
Hey everyone,
TIA!
All the LCA cam hardware part numbers can be found here: Need Cam Bolts and Sleeves? - OEM Part #s.
He needs REAR bolt sir.
Just go to a dealership OP, might be some obscure part number that they’ll order if they don’t have it in stock. Or, go to a hardwares store and get a similar grade 8 bolt.
Ohhh the rear links. I was thinking the rear cam bolt on the front LCA
Thanks guys for the posts! After some more searching I found an expanded diagram of the rear suspension and found my part number! 90119-14119 and it’s referred to as a lateral bolt for anyone wanting to know. Probably why I couldn’t find it searching under “rear LCA bolt.”
erinobr2000
