Rear lift to match Icon CO's up front
That link really helped! Thank you. So one more question. How are they with climbing? Like actual wheeling? rock gardens, slow precision, technical stuff?
They are AWESOME you can just dial in the stiffness you want. On road I run them on 4 which is what a standard ICON shock is set at. For off road running fast in the desert I usually put in at S for Soft which is a 1. You can literally dial in your ride. If you are going to tow you can stiffen them up as high as 9 or turn off the remote reservoir all together by turning it to H for Hard. I have limit straps on the rear and so far the technical stuff has been much better than my Old Man Emu set up by miles. It sucks up the washboard and small stuff at high speed like butter. It's all that and a bag of chips.
All that AND a bag of chips?!?!?! Time to feed the addiction (both suspension and hunger addictions)
I have the icons in the rear but remote reservoir instead of piggyback. If you add the adjustable CDC valves you can dial them in anyway you like. For the rear coil I have OME's. I love the way it handles and I have no sway bar in the rear.
Were these a custom request from icon / for a different model, or how did you get these? As you alluded to, i've only seen the piggy backs for the 4runners.
