Jono.ful
So, for what it's worth, when I went about building the rear end up the MetalTech LT coils never made my list because I knew I was going to be overloading them and didn't want a rear ride-height at or below 2". I started with AllPro 3.5'' coils which were soft but sagged too much under load, which I kind of figured would happen. Then Dobinson's came on the scene with their progressive coils and I picked up their heaviest set at the time. The only trip I took with those was Death Valley and carried around 750 pounds of gear, armor included. It was still bottoming out so they made me an even heavier set which I believe has been added to the catalog. Unloaded it's probably around 4" of rear lift. I haven't fully loaded it due to my accident, but partially loaded it came down to maybe 3-3.5"?
I know hard numbers are needed which I can get later next month hopefully. Either way my point is that it could be a good option for a heavier load capacity coil with extended down travel. Granted the overall rear lift tis going to be taller. These coils are also why I'm waiting on shocks because I need to get under there and cycle through everything to get the travel where I want it. This is not a plug for Dobinsons, just my experience in trying to get the rear suspension where I want it.
Do you know what the spring rates were on the dobinson progressive coils? Heavy metaltechs I have on now are 300/104, hardly any sag after 4 months, even loaded
