Rear Panhard problem?????
Paulo
Hi,
please check the photo below.
The panhard bar is OK??? This picture is from 2gen 1990 t4r.
I have to fix this ??? Or this is the normal shape???
Seems to be curved???
Help please.
Any comments welcome.
Best regards,
Paulo
Thanks Mike!!
I will fix the Panhar bar today.
Another Newbie question.
What is the fuction of the "TILT" control on the left Side of the driving wheel????
My Cruiser Speed isnt working. How Can I troubleshoot this???
Best Regards,
Paulo
Paulo said:
Thanks Mike!!
Best Regards,
Paulo
The "tilt" will allow you to move the steering wheel up and down for a more comfortable driving postion.
The cruise control I can't help you with I have it but have never used this, never heard of much problems with it though, always check your fuses first though when trouble shooting electrical problems.
Mike
what have you done for the cruise have you turned on the system so the green "cruise" light on the dash has come on. If so you also have to push the "set" button on the other side of the steering wheel
I push the left buton an the Light "Cruiser control" is ON
The I press the upper Right Button several times
But nothing happen, If I quit my foot from the accel pedal, the speed goes down.
Any fuses?
Where are the fuses???
Regards,
Paulo
Any fuses?
Regards,
Paulo
Make sure your brake light isn't on. If the light is on the cruise will not work.
The brake Light is off. I alway do the test over 50 M/hr
I just received 2 books, Haynes and ... dont remeber, tonight I will read about my problem.
I will post if a can solve it. Meanwhile, any help is welcome.
Thanks,
Paulo.
You need to push the 'bottom' of the far-right switch to 'set or to decelerate'. The top of the far-right switch 're-sets to previous (while the cruise / ignition is on) or it increases speed AFTER being set. The small , single right button disengages without having to hit the brake. The far left button toggles the entire Cruise System on or off.
Typical use would be :
Push far left button to toggle the Cruise System 'on'.
Hold accelerator pedal with your foot to appropriate speed (usually over 40 mph is necessary).
While holding speed steady, push bottom of far right button to 'set'.
If deceleration to a constant speed with Cruise ON is desired, push and hold bottom of far right button until desired speed is attained.
Same procedure for increasing speed ,,just hold top of far right button in.
Mike in AR
BillM777
