Rear Quarter window template
Daddycreswell
Anyone have an idea of where to get my hands on a template of rear quarter windows? I am looking to cut out an American flag decal for them, but can't find any measurements for them. I have the equipment to cut them out just wish I had a template to work with.
Seems like you live near people.
Why not go a a junkyard and pop out a rear glass?
What I was really looking for is a PDF or .AI file of the rear quarter windows. I don't have a scanner large enough to trace the outline then scan to computer.
Sent from my SM-N960U using Tapatalk
no one is going to give you what you are after because people who need this kind of info either make stickers or make lightweight lexan/plastic windows. doing this would potentially cut into their profit margin.
if you're doing this to attempt to make money, a lot of people already have you beat. i see so many american flag stickers on rear quarter windows. if its just for you, you may be better off breaking down and just buying the stickers (depending on what your time is worth to you).
youre going to have to pop out a window from your rig or a junkyard rig. ive done this on my buddies pickup when he put in a rear lexan window, its not hard. you spend more time popping stuff in/out than you actually do tracing and cutting.
Have you ever found one? If not I will try to make one this weekend. I understand how you feel man....sometimes you just want to make your own kind of flag or some other graphic it's good to have a template to lay out your design on. Why invest in hundreds or thousands of bucks on cutters and then have someone else tell you just buy the sticker from someone else??
Maybe buy the cheapest window sticker you can find, scan it at Kinko's to a file format you can work with and give the sticker to someone as an Xmas gift?
99.99% of the flag decals are larger then the window. Use soapy water, position, squeegee, razor blade excess off and done.
If you have a 3rd gen spray the window with some water and take a garbage bag and “cling” it to the window. Then trim it carefully. Let it flat and bam. Template to make measurements from
Laredotx
