Rear speakers cutting out
Outback Paul
I'm having a problem with my rear JBL speakers cutting out while listening to FM stations. I've never noticed it while listening to cd's. Could it be just a loose cable or what?
If they are loosing the signal then they must loose a signal no matter what the output type is. Yes a loose wire is the most likely thing. Did you inspect the wires at the amp in the rear cargo area?
Where is it at and how do I get to it?
I do not have the JBL system but the amp is on the passenger side and in the rear cargo area. I would start there. If everything looks good then I would yank the dash board off and look at the rear of the head unit for loose connections. Once the head unit is exposed, and if necessary, one could also ohm-out the wires from there to the amp to make sure that it not the wiring runs.
Or you could take it to the dealer.
