Rear springs to match ICON stage 2?
Skinfaxi
My ICON stage 2 kit showed up for my '99, I need a set of rear springs to go with it. I'm setting the front to about 1.5" higher than a stock tall '99, and I'd like the rear to sit about a half inch above that. Currently no added weight in the rear over stock, although I'd like it sprung for a full cargo area (minus steel bumper/tire carrier etc.) Any suggestions are much appreciated!
Edit: Stage 2 is 2.5" front adjustible coilovers, non-remote reservoir, 2" rear shocks.
I would suggest calling ICON directly.. I want to say I read somewhere they designed their rear shocks to go with OME springs in the rear, but not sure which ones at this time!
Icon says it is best to pair thier shocks with OME springs. I have the 890 springs and did no adjust my front coilovers after install.
With how low you're keeping the front, I would run the 890. It may sag a bit if you've got a full cooler, clothes, tent, gear, etc in the back, but it won't be bad at all. I imagine it'd probably bring you to about where the rear was level with the front.
If you don't like the 890 I would yank them out, sell them at a slight discount here on the forum, and try the 891.
Skinfaxi,
I know this is an old thread but did you end up going with the OME 890s? Did that work out wel for you?
906
try ome 906 it will sit level thats what i have n my 3rd gen 4runner
