Rear sway bar hits locker housing
Found it digging around my old motorcycle parts. Metric thread fit perfectly. Of course I only found one so the other bushing has a hole in it.
St runner I’m having the same problem with ome 906s on my 98. I tried using relocation brackets too but was worried that the bar might end up contacting the gas tank since it was closer now. Have you had any problems like that? If not I’ll put the bracket back on.
If it does contact gas tank I was wondering if this option might work
image.pl
Addco swaybars have a different angle so I think it would clear
I have also have been running a 10mm spacer on top of the 906 spring to keep the rear a little higher than the 881 front. I don't wheel it but it does get flexed pretty hard sometimes and I have never hit the gas tank
patnewton
