Rear sway bar link nut size?
montana_jeepn
Lost the nut that holds the link to the frame (97 limited 4x4). Dealer doesn't have them in stock. Anyone know the specs on this bolt? Maybe home depot will carry it. Thanks!
Front sway bar lower nut
Just in case this is useful for anyone, the lower nut on the front sway bar link is size M12X1.25. This nut is rather rare, but I was able to find the last one in stock at Lowes. Home Depot did not carry anything close (not even a 7/16" - 18). Used a locking washer between the frame and the link.
Should you need it, the Toyota part number for the rear sway bar link nut can be found by searching the following:
Stabilizer Link Retainer - Toyota (90948-02127).
With the handy information above I will just travel to my local True Value and find the right sized nut there without even having to remove the one on the other side.
Thanks to everyone from 2013 for the useful info.
wwarren702
