Rear upper control arm bracket
Beagle(4)Runner
Searched on line with no luck. While installing 3' lift on my 99, i noticed that the rear upper control arm bracket on the passenger side was cracked and rusted, PA winters. Does any one know where I can get a replacement bracket to weld on. I have someone who can weld it on, i just need the bracket.
I've never seen them for our trucks, they do make them for Jeeps. You'l probably have to have it fabed up.
Had the same issue with my used 4runner, had already been repaired once so had to replace mount. My mechanic fabbed one up and installed it for $500. It looks at least twice as strong as the factory mount so im sure it will last.
Just happened to me. Passenger side rear upper broke right off.
Off to find a welder....
My new-to-me '99 has a snapped off upper control arm mount. Was a NY truck. What it was attached to doesn't look too great, so maybe I'll just swap in a whole axle if welding is going to cost similar $
AndiGarage
