Rear view Mirror
Dave858
Has anyone installed a Broadway Mirror? Flat or convex? I typically see them on Acuras so it might look stupid on a truck.
i have a convexed broadway mirror on my 4runner. it looks ok, you don't really notice it from out of the vehicle. i use it as a conversation mirror when i have people in the back. it does help me see out of the back windshield although it doesn't do much for the sides. i did pull it out of a honda to put in my 4runner. figured it can go there since i didn't get the auto dim and compass rear view mirror.
I've got one on my daily driver. But if and when that car dies, I won't be transferring to the 4Runner, because it has the auto-dimming mirror. It doesn't fit the dimming mirror because the bottom isn't flat and straight. A friend of mine broke off the two sliding/extending clips and used double stick tape to hold it on his Acura's dimming mirror. I'll probably put it in my Tacoma. The convex works great, I can see out the sides of the rear glass whereas the factory mirror only gives me what's behind the back glass. The convex used in conjunction with the side mirror eliminates all blind spots on the passenger side.
IMO, whether it looks good or not depends on how big of a mirror you get. I've got a 320 or 330mm (forget the exact size) and fits perfertly in between the sunvisors and extends a bit passed the factory rearview. I got a convex. I think the most retarded and useless one is the flat Broadway that is the exact same size as the factory mirror, which is 280mm I think.
broadway mirror pics...
here's the type of view through the mirror...
i don't know the degree in which it's convexed, but it looks like this...
doesn't bother the sun shades while providing excellent view through all of back windows.
I've got one too and it doesn't look out of place. It lets me see out of the rear sides a little better than the stock mirror.
They both look good. Do either of you have the size? 300MM = 11.8 inches, 330MM = 13.0 inches. Damn those Euros.
i'm not sure which one i have, might be the 300mm, there is plenty of room on either side so i'm sure the 330mm will fit just fine without hitting the sun visors. there are also ones that are tinted, slightly blue if i remember correctly, to cut down on the reflection from head lights at night.
I have a flat Broadway mirror, 300mm i think..too lazy to check. I can never get used to the image reflected by the convex mirrors, it has a "stretched" look to it.
Mine is a 270mm convex. I wanted something bigger, but not too big. This one is about an inch wider on each side in comparison to the stock mirror.
MaximussK
