rear window black weather strip
Hi....i saw your post for your 08 Runner on the rear weatherstrip replacement. Can you share the site you used to get your parts. I have to replace the whole bottom strip and the outer seal...i had rust in door so the went in and replaced it but tore up the bottom seal and strip. Thanks for any help or info.
Here's the site I got my hatch window outer bottom seal, it's called a... BELT WEATHER-STRIP - TOYOTA part number (68290-35031)
Link..
https://toyotaparts.lakelandtoyota....ther-strip-6829035031/?c=aT04NDE2NTU1NSZyPTM=
You can find this part from many sources, all around the same price +/- a dollar or two.
Exactly where is the other part you're wanting, if it the seal that is on the body it goes all around the entire opening, not just the bottom, if that's what you looking for here's the info on it... GATE WEATHER-STRIP - TOYOTA part number (67881-35040)
https://toyotaparts.lakelandtoyota....0cnVubmVyJnk9MjAwNyZ0PXNyNSZlPTQtMGwtdjYtZ2Fz
You should be able to find it at other sources but not sure if the price will be better or not.
