Rear Window Motor
194runner93
Its seems that everyone has this problem with there rear window, but no real fix that I have found. My problem is that my window wont go up or down and the rear door wont open either. Is there a cheap way to bypass the window motor so the key can open the rear door? I can really careless that the rear window wont work I care about me being able to open the rear door. Anyone?
real easy fix is to repair the window so it works properly.
there are a ton of write ups and info on how to fix any issue in the rear window!
take your time read and learn.
if you need the window down you can take out the motor from the regulator and the window will go up or down by hand but it wont stay up unless you put the motor back in.
pax at 4
