rear window problem and hatch and hood
thorridder
alright so a long time back the rail on the passenger side fell off, so if i moved it the glass would fall, so i stopped using it and i hate it. now i fixed the rail but it stopped working. the button on the dash and and the hatch key wont work. and to top it all off the hatch is basically stuck shut like they get AND i misput the hi-lift when doing the BL and it bent the hood latch so the hood it stuck down too. help?
i've seen your ride you thatfool who drifted in the parking lot right, with the s/c, as for you problem use a volt meter and check all connection
hmm...
odd...
i copied your post and put it into google translator. i used "detect language" and tried to translate it to english... when i clicked "translate"...
google crashed.
like i said, cant open back or hood so cant
and i dont have a super charger and im at OSU in OK so i dont know if you did or not
I'm not really sure what you want us to help you with. It seems pretty obvious that you need to open up the rear hatch access panel and check why the glass is off track.
That or maybe just take it to a mechanic.....
Ok, I spent a good 10 minutes trying to read this, and these are my resulting questions..
-Did you check the fuses?
-Can you use more adjectives please? I have no idea which "rail" you are talking about.
-How did your hatch get stuck closed? Explain please.
-You used a Hi-lift jack on a vehicle with no hi-lift jacking locations to install a body lift?
Excuse me if my questions don't make sense to you, I don't expect they will.
back glass: on wither side of the back glass there are guide rails inside the hatch to keep the window level. one side the bolt came out, and i recently put another back in but now there is and electrical problem now. i could not find a fuse that would go to that kind of thing and i really looked. and the front button in the dash and the rear key to role the window dont work not but did when the bolt fell out.
hatch: i know it happens with others and it has happened to me before but not this bad. the hatch is stuck closed, i pull and push on it to try to break it free and it worked at first but wont now.
hood: when putting on my 2"BL i put the hi-lift right on the front by the radiator where the bracket that holds the hood latch is, now i cant get the hood open to look in there. i found good points to lift but that was thin metal with no structure and i didnt lift it much at all but that was enough to stop it from opening
ok obviously this will be no help with you guys. i dont know who you think i am and i really dont care. you may think im some stupid kid who doesnt know anything but im not at all, im f**king 20 and an engineer and can think and build out more than most 4Runner guys one here. i may not be a 4Runner know it all bc i have nobody to help me. so just f**king back off my s**t. you guys are nothing but people wanting to bad mouth and smash guys over the internet. oh your so cool you have an expensive car you drive around *extreme sarcasm* we congratu****inglations, i also have a 65k vette in my garage too but that doesnt make me hot s**t like you think it does you. so peace out.
Hey. I did try to help you. I told you to take it to a mechanic because if you think that lifting your truck by the core support is a good idea, then you should not be working on your own truck. I'm sorry if that makes me seem like a douchebag. But it is true.
Sorry but you're not an engineer, you are maybe in school for it still tying to get past genernal chemistry. IF you become one, let us know what you design so we can stay away from it.
Any engineneer would diagnose thier own problems and figure out the best way to remedy it.
Talyn
