Rear Wiper End Part Number
fenrisx
Anyone know the part numbers for this piece? I was trying to get the two screws out and the whole thing snapped into pieces. So, I've been running with no rear wiper this winter which isn't fun on snowy days.
There's an aftermarket part from Anco (pn: 48-08) which is the brack with the two screws...which would allow for aftermarket wiper blades, but the bottom rubber piece isn't included (the piece that helps it seat correctly when not in use).
Thanks T4R!
85247-35010 slider subassembly
90099-00925 Screw - order 2
For a 97 4runner anyway, these are the parts
Not totally off subject for the rear wiper arm but, I had to replace my wiper last month, cannot find anyone that sells the wiper blade assembly other than the toyota dealer...$10 more or less to replace the entire blade.
I was wondering if it is possible to replace the entire arm with something a bit newer, that allows you to remove/replace the blade much the same way as the fronts, and that will work properly, yet, when I need to replace the blade, I can buy the blade replacement from someone other than the dealer?
Trying to screw those two screws back in with the new blade - a bit of a PITA.
Thanks,
Michael
