Recall coming on sunroof
Go to an independent sunroof shop. They might be able to do it for cheaper. I had the sunroof go on my 93 celica and when I went to the dealership, the service writer was honest enough to say that they would just outsource it and charge me extra for the dealerships time. I took it into a shop and they charged me $500 and they ordered the parts from the same dealership I had gone to.
My sunroof just jammed yesterday. I tried everything to get it shut with the rain coming. It is jammed in the all the way back position. We tried everything to get it closed....but no luck.
I drove like a bat out of hell to the dealer this morning. The Passengers side would want to come forward but the drivers side would not budge.
After talking with the dealer he said a part near the back had broken. I did not get into specifics, but they tore out the headliner and are goign to fix it. He said it will take appx a day to fix. I will keep you posted on what it needed.
I don't have a sunroof in my truck, but isn't there a way to manualy close it? My Acura had a special tool with the jack/spare tire. You could use it to hand crank the roof closed.
Fix
You're having the exact same problem I do. Please let me know how it goes. I'm driving around with the sunroof plasticed and duct taped. Since I'm out of waranty I found the parts much cheaper online and I plan to have an independent mechanic to the work for much less than the dealer. I'm planning on waiting a week or so to get the work done becuase of my schedule.
Unfortunatelly the 4Runners don't have a feature where yo can crank the roof closed. Basically you're forced to pull down the headliner. -J
I will let you know of hte paperwork of what they required to fix it. As soon as I get the parts I also have a parts list with numbers and pricing and can help you out. I do know they had to tear the headliner and hte whole sunroof out. Labor would probably have been a bitch to pay just for that reason. Im picking it up this afternoon so I will let you know what I find out
Problem Fixed
This was the Dealers take on it
"CUST REPORTS THE SUNROOF WILL NOT CLOSE.
SUNROOF WAS OPENED AND WOULD NOT CLOSE. FOUND REAR CORNER STUCK IN TRACK
REMOVED SUNROOF REMOVED GLASS
FREED UP CABLE BUT COUND FIND NO REASON FOR CABLE ASSM TO STICK IN TRACK. PART ORDERED
REPLACED SUNROOF HOUSEING AND CABLE ASSM
1-63205-35030 CABLE SUB-ASSY, T $1163.28
1-63203-35041 HOUSING SUB-ASSY, $579.11
3-90467-12080 CLIP---not sure of pricing-think like 50 cents
2-90467-11111 CLIP---not sure of pricing-think like 50 cents
It was under warranty. I put prices out to the side and that is minus the labor and the markup on the parts..so thank goodness for warranty. Definitley investing in an extended warranty when my 36K is up. For anyone with an 03-05 is probably a decent investment. This would have paid for itself and then some.
Wow.
It almost seems like the sunroof is THE most problematic part of the 4Runner.
Mine has one and I use it often. I love driving on a sunny day with both the sunroof & the back window down! :D
It might be the fact that only a few vehicles (all of them Toyotas) can do this. ;):
So far, no problems (knocks on wooden head).
Of course, my truck is only about 9 months old so... :bash:
snap315 said:
Wow.
:iagree:
Mine rattled bad and had to have it fixed. It has also jammed on me twice but both times I helped it close and it did. Worked fine afted both occasions so the dealer said there is nothing he can do but it is noted in my records becuse I told him I'm concerned about when the warranty runs out.
toybox said:
:iagree:
Well, mine rattled and got the "moonroof" fix. Then it started creaking and making grinding noises and I was told nothing was wrong. Finally it got stuck twice (was able to get it to close by holding down the wind deflector) and I brought it in to dealer but the tech said nothing was wrong. I had shown service person that when it opened it raised up higher on one side. He had to go back and show tech and then they decided to fix it. Had to replace cables which were ordered and shipped from Japan. Moonroof on this vehicle is , in my opinion, one of the most problematic components. However, I do think that the quality of materials used in the 03 is not the best overall. I have an extended warranty but since I had complained about the moonroof several times before my standard warranty ran out, the standard warranty was applied. I am most probably going to get a new vehicle before the extended warranty expires. I just don't trust that it will hold up as well as it should.
No Recall on Sunroof!
The sunroof on my 2004 Sport locked up last weekend. Took it to the dealer and they had it for 2-days. They replaced everything mechanical for the sunroof, including the motor. The only thing they reused was the glass. They did a very good job, even reinstalling the headliner. Dealer said they are NOT doing a recall but will fix them if the problem exists and it is still under warranty...duh? I first noticed a banging noise last fall and they couldn't find anything but I'm glad they noted it on the workorder.
For others who have not had the problem....it's not a matter of if, it's a matter of when. I will probably buy the extended warranty also.
Moonroof jammed for good yesterday
2 yrs ago, my (2003) moonroof was changed out (supposedly). Vehicle was in shop for 34 days because after changing the moonroof, they trashed the headliner. After a week of waiting, they told me the liner was coming from Japan. Then, a week later, from Toronto. And finally, from California. Funny that in the US they pass the buck to Canada. Any way, a screw is stripped in the driver sun visor; the drivers seatbelt clip (on the column behind your shoulder) was cut by a screwdriver I guess; the plastic plugs holding the rear shoulder straps were damaged so bad that the jerk went so far as to glue them in! In the end, the headliner was still marked from careless installers at a local dealer. They gave me replacement parts for the damaged plastic covers.
Two weeks ago, I heard a popping sound as it was just about fully opened and it jammed open. It sounded as if 3-4 cogs in a gear were jumped. Somehow, pressing down on the wind breaker and toggling the switch to the on position several times caused it to close. Whew! I made a mental note to take it to dealer before it happens again.
Well, last night after sitting in the sun watching a ball game, I opened the damn thing and after the same popping sound, it's jammed open but good. ARHG!!! Like another member, it seems to be the drivers side thats sticking as the passenger side moves forward. It's going to rain tomorrow and I'm not wiling to leave it at the stealers for another month so I'm going to close it myself and get the dealer to order a new one in the future. Regular warranty is up in Nov/06. Extended for another year, but the dealer mumbled that the extended may not even cover that.
I too have not been exposed to the Toyota Experience, but I have been exposed to a typical Stealer Experience!
It took 7 hours, but I removed the interior panels, head liner, and moonroof and fixed the problem. Well, I guess it's not actually fixed as it's defective, but it is working again. Would you believe that the stealer said it would only take 30 minutes to get the window closed?!? What a load of baloney!
I never thought to take pics! Dang! The problem is at the very rear of the drivers side. It's the shaft that you can see moving back and forth while looking down at the open window while closing/opening it. Way in the back, the shaft jumps of its normal position and gets caught up on a piece of aluminum that is jutting out about 1/2" from the very end. Because of the way the motor and cables work, I used a narrow screw driver and forced it (very hard) back into place as the motor gave it's initial yank. There's no way you can correct this by hand from the front unless you want to clamp onto that silver shaft and pull strait ahead. You'll probably bend that shaft or rip it to pieces. When it jumped back into it's normal position, I heard the same popping sound that I heard when it broke.
At first, I thought the tiny protruding piece of aluminum might have been caused by the system, but the passenger side has the same thing. I suspect that the main reason it even gets off track is the lack of lubricant at the rear channel. Mine had a lot of dried up grease. In places it looks like the factory lubes turned to some sort of hard epoxy like substance. It's very weird stuff. Still, if it was the lack of lubricants, that would suggest that the passenger side should also jump it's normal position, but all the posts I've read on this and other boards suggest it's only the drivers side, so it must be a design problem.
In the process of removing the interior of my rig, I discovered that when the stealer replaced this moonroof 2 years ago, they really did a lot more damage than I originally discovered. They broke several plastic covers; glued 2 covers in place (as the broke them); used self tapping screws in places that needed metal (straight) screws; and used those metal screws in self tapping areas. The also lost several of the little white clips at the back of the wall panels that hold the panels in place. What a joke! Make damn sure that you check all the work the stealer does as you might end up with a load of garbage when their done!
I'm debating whether to make this jam again and try and get a new one, or just live with it. I'm leaning to just living with it and learning a lesson about having a moon/sun roof.
Anyone in the Vancouver area that wants guidance to fix their moonroof, send me a pm.
Mine did the exact same thing yesterday. What pisses me off the most is that the 4Runner was at the dealership last week for 4 days while they fix a recurring brake issue. I had mentioned the problems with the sunroof. They said they couldn't reproduce it.
The VERY first time I opened the sunroof after picking it up, it stuck. Couldn't get it closed. Took me 30 minutes of trying. Same description as yours. Passenger side would try to close, but the driver's side wouldn't budge.
How do we get Toyota's TSB division to understand that they have a design issue and new sunroofs need to be made, delivered, and installed BEFORE all factory warranties expire?
Ha ha. Good luck with that. It's just like the seat rattle. They know, but just will not offer a fix.
So anyone know anything about this recall that is supposedly coming, per the thread title, or is this just wishful thinking.
My wife and I had the same thing happen to us last night on her 05 4Runner: I opened the sunroof and it made a grinding noise...I tried to close it but one side seemed to be jammed (in the open position). Needless to say, we were very frustrated that something like this would happen on an 05 with 9K miles, so I took it in to the dealership the first thing this morning.
I'll update this post once the problem is resolved, but so far, I am extremely pleased with the service department (Gene Reed in Charleston SC). They were very quick to give me an 07 Camry as a loaner and I was on my way.
Sunroof Stuck Open
Yesterday our Sunroof (04 4Runner) got stuck open. My wife said it made a clacking noise and then it wouldn't close. It starts closing and then reverses. I was able to pull it closed while holding down the wind deflector and holding the switch. Does anyone know which fuse controls the sunroof? I think I'm just going to pull it so nobody tries to use the sunroof. We've had our car 36 months and 2 weeks. :mad: Figures...
I would definitley take it to the dealership. THis is a known problem and they might give you a tough time..but I would fight it. I think I mentioned in this thread the cost to fix it. Was not cheap, So I would definitley fight this.
AndiGarage
