Record time replacing spark plugs 2005 V6 4WD 4Runner SR5
tcpoob
It's a record - slowest :cry2: Altogether, maybe 5 hours, split in two days, Sat afternoon and Sun morning. I know, how could it take that long! But, next time i do this, i would break the record - most improved.
1st spark plug change in 92k miles. i was worried the plugs would corrode and get stuck in the heads.
i'll attached a picture of the old plugs 3 denso and 3 ngk, as most experienced.
Encouraged by the Tacomaworld guide with pictures for 1GR-FE, i bought the Denso OEM plugs Sat. Boy, it's a ripoff. 6 x $4.79/plug before tax. also bought a wobbler extension with spark plug socket - invaluable, from autozone, and a packet of anti-seize.
started at the easier passenger side, which took yesterday afternoon. the wire harness going into each coil module was giving me trouble. wife helped prying them off (both passenger and driver side) - besides watching the kids.
inserted the wobbler extended spark plug socket into the 1st head after coil pack was removed, but it felt stuck as i didn't how hard to turn. didn't want to risk breaking it in the head, so i ran to a neighbour who came over and showed me how (hard) to turn to loosen it and back it out of the head. they were fairly tight and i am only 5'8" so it's hard to use the body weight etc. Eventually got them all out. Applied anti-seize on the new ones and hand tightened, before turning 1/2 or 2/3 of a turn with rachet. oh, anyone can recommend a good torque wrench?
it was dark so i called it a day and fired up the ride, and drove it back to the garage. Resumed on the driver side today. the bolts holding the surge tank stay bracket were fairly tight. took quite a while to get the top one off and bottom on loosened. decided might as well remove the whole sucker to have more room - i heard most of you just loosen the bottom bolt and swing it out of the way. anyway, repeated the procedures yesterday on the driver side, except it's quite a bit slower because of all the wirings resulted in limited room to maneuver the wrench.
Got a question though. i think i made a mistake when putting the bracket back. i replaced the bottom bolt in the middle hole when i think originally it was probably on the left. didn't look like it would matter. i'll attach a picture if you don't know what i meant.
i am seeing a mechanic for the "flying saucer" (bearing or rear diff) noise i reported about two weeks ago here. the dealer never called me back after telling me it's a passenger side rear wheel bearing problem, when i agreed to a fix and requested a discount from their repair price quote $800+. The recalls are keeping them busy, i suppose.
i have yet to fire up the ride but i'll this afternoon to see if it's any smoother or even starts ;-) Thanks.
pictures for used denso and ngk plugs and misaligned surge tank bracket
as promised, taken with crappy phone camera
5 hours! Well at least it's done ;)
And you learned a lot!
I checked mine and yes it should be on the left thread.
I don't know if it matters, but they put it on there for a reason. Why mess with Japanese Perfection!
Reminds me...my are going to be due for a change AGAIN soon...sigh.
Whichever one you get, I have a craftsman, remember to turn the dial calibration back down to zero. That way the internal mechanisms don't get messed up.
i take it that you are talking about torque wrench - turn dial calib back down to 0 when done.
After doing a bit of research i found out that most Craftsman Torque Wrenches are just horrible...... I mean don't leave it up to me just do some research on most of their models.... I would recommend a Kobalt 3/8 Torque Wrench from your local Lowe's!!!!!! Around 100$$$ or less on sale and it's a beast i think if goes from 5-100!!!
