Refresh me on front brakes/rotors
Ghostrider
Registered User
Haven't done them in a few years and watched a video or two and noticed a few things to ask
1. Torque on caliper bolts?
2. I remember hitting the back of the new pads with anti sqeal but never saw this step in videos. Any rec's
3. Same question for lube on slide pins.
In case anyone is wondering - all OEM Toyota pads/rotors. Tried to find brembo locally without luck and a nearby Toyota dealer had rotors for about 67 bucks and no shipping charge.
I'd say "good n' tight", I mean it holds the caliper in place.
anti-rattle/squeal is nice, i forget sometimes and it doesn't matter.
I mean a guess slide lube is OK, but again unless they're all rusty not an absolute requirement yet why not on all lube points huh?
This was done on a 1st Gen Tacoma but it's the same on a 3rd Gen 4runner.
Or, maybe go for the Tundra Brake Upgrade:
I believe the OEM pads come with a little packet of grease that is spread out under the shims that you should have got with them. Don't grease any exposed brake hardware, it just gets caked full of brake dust and road dirt. There is no need to grease or apply anti-squeal stuff to the back of the pads, that's what the shims are for. The disc brake caliper lube is for semi-floating calipers with sealed guide pins. The orange disc brake anti-squeal is for the old metal backed, riveted pads that didn't come with any shims or coating on them.
Thanks - interesting that the caliper bolts have a higher torque than lug nuts
Too much torque will crack the aluminum rim at the hole.
A dealership cracked a AR39 rim I had on my Cummins from too much torque. I didn’t catch it until I put new tires on it and when we were balancing it required way more balance weights. Then John and I seen a crack from the center to the lug stud hole.
Edit. But that’s what I torque my wheels. 90-100.
You are correct that the OEM pads come with a grease packet and it's for the shims. You're suppose to spread it on both sides of the slotted anti-squeal shim. People who have gone with aftermarket pads make the mistake of discarding the anti-squeal shims. These shims could be reused for the life of the vehicle provided they don't get destroyed from rust.
Not to difficult. Took a little over 2 hours. One or two comments
1. Yep the factory shims come with grease but don't count on having any left. I bought new shims
2. The outer pads are actually labled Left and Right on the back. I just happened to notice this.
3. Lug nut torque - owners manual says 83 but my Toyota FSM says 76 - went with 83.
Only issue was it took forever to get the top caliper bolt back in the hole on left side. I had the bottom one in and it would not "find" the top hole by pivoting. Spent probably 15 minutes screwing with this issue.
Good job gettin er dun.
ghengiskhan
