Remanufactured injectors?
You can buy the stuff and rebuild them yourself. My build and repair thread shows how to do it.
I've never heard of AniraMotors, but they seem a little on the cheaper end of the spectrum. Yotashop is a reputable shop, but on the high side if you're trying to replace all 6 (which I would recommend). There's a lot of people that have used these MotorWest injectors Denso Fuel Injector Upgrade Set for 3.4L V6 4Runner Tacoma and Tundra – HP831 – MotorWest Performance without a problem. $240 for all 6 seems like a good middle ground pricewise. They are "upgraded" injectors.
I agree with Patrick. I would suggest you get a full set of injectors from Motowest Performance. I've met the owner Martin Diaz in person and he's a good dude and stands behind his product. He offers a lifetime warranty for the injectors he sells. We used Motorwest injectors in the video below.
<iframe width="560" height="315" src="https://www.youtube.com/embed/N-lhZIWOkyU" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Did this in my build thread somewhere as well.. cost a can of carb cleaner and like 20-30$ for the rebuild kit. They don’t make all the little parts oem anymore so you gotta get it off eBay. Toyota still sells the o-rings/seals but not the filters/Pintle caps (as far as I could find anyways..)
I ran the motor west rebuilds with no issue, not sure if the price listed is still current. a few years back they would then give you back $60 for your old ones. Or you could send yours to them and it was less than buying the ones ready to go.
I too have "rebuilt" some in the past, but no way for me to know if flow matched, but I had no issues......but those were on a BMW and on a volvo
Thanks for the info everybody. (Bad Luck, you’ve steered me right a couple times before so thank you extra)
One other related (novice) question - when doing the injectors, is it best to also do the valve cover gaskets? Am I causing a lot more work for later if I skip the valve cover gaskets during the injector install? I realize they are unrelated - it’s just that my gaskets are leaking and due for maintenance, but I can drive with the gaskets the way they are but I can’t drive with the injectors the way they are right now.
You are already most of the way there by the time you pull the injectors, midswell do valve cover gaskets as well IMO.. Basically you’ll end up doing most of what your doing twice if you wait.
Yeah I figured as much. Ok thank you. Might as well do everything I guess
I would definitely recommend doing the valve cover gaskets while doing the injectors. It’s not a difficult job but it is time consuming and there is a considerable amount of overlap in the jobs so it certainly makes sense to do both jobs at the same time if both repairs are needed.
I went OEM with all parts when I did my valve cover gaskets and have zero issues. Some have gone with aftermarket parts and also report no issues so the choice is yours....all about comfort level and available funds.
Several great write-ups available with video/pictures. I basically looked at all of them and had no problems.
Take your time, label parts during disassembly and take pics.
It gives you an opportunity to clean up your engine bay, especially after living with leaky valve cover gaskets.
see I did it backwards to what people above have posted.
I had 200+k miles...needed to do the vc gaskets....so I then added injectors to it as preventative...since I was so far into it.
Currently I’m getting misfires in Cylinder 3 and Cylinder 4, so unless 2 coils went bad at the same time, it’s probably not the coils, and since I need new valve cover gaskets anyway, and the engine has 275,000 miles with mostly original parts, it seems like a good time to do all the injectors, plus plugs and wires. Unless there’s something I’ve missed. O2 sensors and plugs/wires were done 70,000 miles ago.
So kind of like your scenario 3bears. Which injectors did you get?
Might be worth troubleshooting the misfire before dropping $ on valve cover gaskets.. you can move plugs/coils around and see if the misfire moves. If it does you found your problem, if not you know those things are probably good and to focus on other items to fix misfire. Might be worth renting (free) a compression tester from orielly/autozone too..
If you're chasing a misfire I would recommend replacing spark plugs and wires first before ordering injectors. It sounds like you're due to replace spark plugs and wires anyways, and that may be your issue.
In the words of The Big Lebowski, my thinking on this case has become very uptight.
You guys are right - I need to start with the top level stuff first. I’d kind of come to the same conclusion in a roundabout way, and did the plugs today. Waiting on wires and coils to arrive from RockAuto and then we’ll see how it goes.
I do think I’ll change the injectors when I eventually tackle the valve cover gasket leak — I just don’t necessarily need to do all that right now, if the plug job gets the misfire.
So far so good. I replaced the plugs, wires, coils and O2 sensors, and cleaned the MAF sensor. Check engine lights are now off and it’s running well - no more misfires (though I’ve only driven 30 miles so far)
I still need to deal with the leaky VC gaskets sometime soon.
I’m a little concerned about the plug install b/c I didn’t have a torque wrench. I tried to not make them too tight but what are the risks if I got that wrong? I did them finger tight plus 1/4 turn with the socket and they felt quite tight to me at that point.
Also, a big shout-out to TheDurk in this thread:
02 sensor replacement???
I couldn’t have done the front/upstream O2 sensor (actually an Air/fuel Ratio sensor in my case) without this info. He’s exactly right - you pass the sensor over so you can more easily access the electrical plug. It’s a bit of a pain but do-able. Thanks TheDurk!
- I’m posting this to help future searchers.
I'm glad you got it figured out! As for spark plug torque, I think you'll be fine where they are at. You might be a little high, but I don't think you're at risk of thread damage or cracking the head.
