Removal of Painted Pin Stripes?
ObrienActual
Hello - Purchased 4-Runner new (14) and dealer had painted pinstripes as part of a package. Okay with look but a few areas have been dinged / washed away.
Have searched all over and there does not seem to be a clear (safe) removal method. Have seen people recommending Acetone, Lacquer Thinner, Oven Cleaner, and Wet Sanding.
What is the safest method in order to not damage car clear coat and paint. Willing to pay a shop if necessary.
Disclaimer: I'm not a professional etc... try this on your own and don't come to me if it damages something.
If they are just stickers, you might try a hair dryer or heat gun. With that said, if you use a heat gun you can cook your paint pretty bad, so start low and move up.
YouTube
If they are flaking off, a buffer wheel might just knock them off too.
What you might see after you remove them is your original non-faded pain color and have a new pin stripe.
YouTube
Thanks, but these are painted.
Probably depends on what they used and if the paint had hardener in it. You can try lacquer thinner and slowly wipe it on without putting too much pressure on it. It will be a long process if it works. Would be a good idea to put a buffer on it afterwards.
Heat gun is good idea even for painted stripes because it'll soften that material. If you have small detail polisher it will take no time to level this down to paint with just some polish and yellow pad. Be careful not to burn trough original clear coat under that stripe. G.L.
Have tried a polisher and compound, little result.
I used an eraser wheel on a drill to remove large decals from both sides of one years ago, worked great. Think I used the second wheel on some pinstriping later as well. Something like this although can't vouch for this particular brand - Amazon.com: Decal Remover Eraser Wheel. Remove Car Decals, Vinyl & Stickers in Minutes with The 4" Wonder Wheel Toolkit - Arbor Supplied: Automotive
Prob be cheaper at auto parts store if you can find
Have seen the wheels work magic on vinyl.
I have seen these exact pinstripes put on a camry. It’s a decal/sticker, not painted. Maybe they told you it was painted. Did you buy from the HB dealer that sold the barcelona red pro to the other guy?
Definitely painted, I have removed some. You can also feel the difference between a vinyl type stripe and paint.
Rubber wheel with finesse
Have seen these work on vinyl but not anywhere online for paint.
Definitely not painted. Like others above said, you can use a heat gun or wait for a pretty warm day in conjunction with a heat gun and they should peel right of with little to no effort. Pin striping to me is such old school graphics. I hate the way it looks on a modern vehicle...just my $.02
He insists they are painted. He could be right but I highly doubt a dealer would take the time to paint a pinstripe like that unless they added some giant ass markup for it. Also as I mentioned earlier, I have watched them apply these pinstripes on a camry before and it looks exactly the same.
I find it hard to believe that the original dealer hired a pin stripe guy who can paint them (a dying breed) to paint boring parallel stripes on your 4Runner when nearly 100% of these vinyl appliques are done badly by some idiot they don't trust in the sales or service departments.
I’d be shocked if they’re painted as well. That’s a pretty uncommon practice these days. No way a dealer will pay that as mentioned without a huge markup. IF they are painted, lacquer thinner should take it off without affecting the clear. I have used lacquer thinner countless times on touch up paint on multiple vehicles. They clear is very resistant to it. The edges on vinyl will be super clean and not that way painted.
I haven’t seen painted pin stripes in years, only at a classic car show. A vinyl stripe usually wraps around the door edge where you can start peeling it off. Try a hair dryer to heat it up.
I would highly suggest not using a heat gun unless you want to peel off the factory paint. The pic sure looks like hand painted pin stripes.
Heat gun while using correctly won't damage already cured paint as long as you are using common sense.
I had painted pinstripes on a Ford Focus in 2004 or so. I used oven cleaner from Dollar General. Worked like a charm. Immediately wash car after just in case but I had no problems with it.
Haha, you guys are tough.. Have included another photo showing the striping at door gap and you can see the start / stop marks. As mentioned previously, I have removed some and included a photo of that as well. The sun burnt bird sh*t on the paint and left some ghosting. Used some turtle wax bug remover and it took off the striping. Went back with compound on a polisher and minimal result.
Damn. The crazy bastard actually PAINTED pinstripes.
Wasn't as much saying you weren't telling the truth as just who TF does that these days on a car that isn't a custom?
Deka
