Just keep this in mind - when you remove double decker you not going to have a flat floor anymore. Very useful if you happen to sleep in your truck on camping trips.
Interesting ... at 6'1", I don't seem to stretch out enough to be able to sleep comfortably in my truck, but I'd still like for the floor to relatively flat. Are you saying that if I removed the double-decker and replace interior panel with the correct panel it will still not be flat? Is there some other difference between the two that needs to be taken into account? Or are all trucks w/o double-decker not flat?
Take out the rear seat bottoms and you will have space.
Thanks ... I've never considered that, will have to look into it (removing seat bottoms). Under normal circumstances I don't have a problem sleeping in a tent, but there are certainly occasions that it would be a lot simpler to sleep in the 4Runner.
I'll post a pic if you're interested.
Some pics would be great ...
I removed the DD from my girl's 06 and have yet to find a solution to the gap. I did get her a Husky liner for back there (we have two Labrador retrievers) so you can't see it, but I would like a better solution. I am open to a deal for somebody that is interested.Does anyone have any experience removing the cargo shelf? Seemed like a good idea when I bought my 06, but at this point I never use it ... seems that nothing I carry is ever a good fit. So I'm thinking about removing it and am looking for pointers ...
Interesting ... so does the metal bracket simply act as a support to hold the plywood at the correct height? And do you have the bolted onto the metal bracket? If so, do you think a longer bolt could be used so that you could bolt straight through to the body?That's 1/8" thick metal that I bent with a vice, hand clamps, and a mallet. Then some plywood and Kraco Carpeting ($10 at O'Reily).
This is why I like muscarellaw's solution above ... it's cheap and would usually be covered by my weathertec cargo liner.I removed the DD from my girl's 06 and have yet to find a solution to the gap. I did get her a Husky liner for back there (we have two Labrador retrievers) so you can't see it, but I would like a better solution.
Can't say if the new trim would be flat (although it seems like it should), but can say that unless you can find it used, part # 58401-35010 seems to be running about $181 or so ... plus it's possible that you would need two additional trim pieces (64721-35020) that run about $16 each. That's from http://www.toyota-4runner.org/4th-gen-t4rs/3531-parts-replace-double-decker-storage.html, but he never posted pics ...Can anyone say for sure that if you buy the trim piece it would be flat with the seats down? Can't stand that POS and would gladly shell out 120 to get rid of it...
Makes sense ... thanks!It is bolted to the plywood and it is used to support and hold it at the right angle. I don't think you could use one bolt because of the angle. One thing, if you're planning on trying this put the bolts in before you bend it.
