Removing rear shocks, an easy way?
Deezil
I have a set of airshocks to put on, but they look like a PITA to get to the top little nut? any tips before I tackle it tomorrow?
I removed the bottom bolt and bent it back and forth to break it off at the top. Only took a few times to work since mine were the originals and pretty rusty.
Ive thought about a lift of some sort, but if I put on bigger tires itll have less power, I need all I got, haha
You dont have to go super huge, I have a 1.5 inch body lift and it made the world of difference changing those rear shocks. Its fairly cheap too. I can direct you where to get them if interested.
On the driver side rear, I used the sawzall method but didn't cut high enough and had a hell of a time getting the rest of it out. :ybrick:On passenger side I held the nut with a ratchet and used a strap wrench to turn the shock. Driver side took several hours over two days. Passenger side took 5 minutes.
Reading this thread title made me cringe. I fricken hated replacing the rear shocks. Hope the advice given works for you.
I got a 14mm deep socket and breaker bar on the top nut and then just rotated the steel top boot with my big ^%$% Channel-locks. It snaps just below the nut in one pull. An hour to figure out how to do the first one, two minutes to do the second. I'll race a Sawzall with this method anyday (as long as the shock has a steel boot like the stockers).
