Replace Diff Breather Plug?
1000MPH
Senior Member
Watched this vid today that showed a TSB I’ve never heard of before. Says...
“The breather plug should be replaced during any differential/transfer case repairs to prevent possible repeat failures. The subsequent use of the original breather plug after a repair has been found to contribute to the failure of the differential/transfer case components. Replace the breather plug when replacing differential/transfer case components.”
2009-2015 4Runner
Toyota T-SB-0047-16
Here’s the vid...
https://www.youtube.com/watch?v=KroYmPAbOYM&feature=youtu.be
2009-2015 4Runner
Toyota T-SB-0047-16
Here’s the vid...
TSB!
Here is a link that is way beyond the TSB curve.
Do yourself a favor, don't wait for a failure.
Rear Diff Breather Mod - Complete!
Hmm, yeah I would totally believe that they aren't very reliable. the first time i changed the rear diff fluid, the case had negative pressure. i was pretty surprised. i pulled the breather and knocked it around a bit, the thing was plugged with fines. i just extended it up the by the fuel delivery tube.
So are these things not supposed to be one-way valves?
In general they are supposed to be two-way. You don't want negative pressure in your diff, that is what will cause foreign material to be drawn in. If anything, you would want positive pressure but really it should have the same atmospheric pressure as outside of the case.
