replacement headlight bulbs
Im looking for something brighter for my 97 also, i,ve read dozens of pages here am still totally confused! good information on the "candlepower" site.
I just need something to replace one that is out, so I'll do both. Don't really care if it's brighter, but I want something decent I guess...
Prefer to order from Amazon so I don't have to go out to get it...
Buy any name brand bulb and it will be fine. No need to get too cranial over the subject matter.
The stockers are probably what's in it now just to give you an indicator that bulbs aren't something that go bad quickly.
I disconnected my DRLs and installed Silver Star Ultras right after..... that was 3 years ago and no failures!!
I used to have silverstar ultras and one burned out in ~9 months. I replaced them with PIAA xtreme white, and they're way brighter.
Amazon.com: PIAA 15224 H4 Style Xtreme White 12V 60/55=110/100-Watt Bulb - Twin Pack: Automotive
I had similar bad luck with Silver Star Ultras, and then went with these NightTechs from PIAA on a recommendation on this forum. Also much brighter, and apparently a whiter (less blue) color temp.
http://www.amazon.com/gp/product/B00544ZD86?psc=1&redirect=true&ref_=oh_aui_detailpage_o02_s02
They've been in since September, 2014--over twice as long as the SSU's and still going strong. One review says they are better at throwing light long distance than the PIAA Extreme Whites, which is what they are supposed to do. Needed for the twisty back country roads I drive.
9003 Bulbs, go to the autoparts store and ask for 1 9003 bulb, usually they will install it for you to.
now some of you have newer models with clear lenses, for those of us with the older diffused glass, do you think a particular bulb would lend itself better to these?
I have the old style headlights. The PIAAs work great in them. I'm sure they would be even better in a clear housing however.
It's hard to take pictures at night of anything with an iPhone, and pics of headlights are even harder. But here's a pic that kinda shows the difference.
In person the difference is much more pronounced.
just bulbs or did do the aftermarket wiring harness also? which bulbs are the way to go? thanks!
So I bought new bulbs, but how do I get the old ones out? I can pull the adapter off, but the bulb itself won't come out. Do I just have to pull harder? I don't want to break anything...
