Replacement heads
As long as you keep posting on this subject I'm going to keep hammering you to just buy the helicoil kit and give it a shot. That helicoil taps the threads quite a bit larger. I think there's a very good chance there's enough metal there for you to be able to tap it successfully. I understand the spark plug caused damage to the hole but you've got nothing to lose. Spend the $30 and give it a shot. If the hole is too wallowed out and the tap doesn't bite, you're out nothing because you can send back the kit for a full refund if you buy it via Amazon.
I hope your next post is you saying you bought the kit and you either report the repair worked or no it didn't and you have to search for another fix.
Can you link it again? Went back looking and didn't find it
chasebradshaw
