JP4RNR said:Anyone know how the body molding is attached to the body? Is it just clips and adhesive or are there nuts that need to be loosened from the inside of the body panel? Mine is scratched and it is actually cheaper to buy it already painted than it is to take to a body shop
How much did you get charged for molding?
JP4RNR said:It was the rear left quarter panel molding. It lists for 150.00 from my local Toyota Dealer but I got it for 50 bucks less at 1stToyotaparts.com online for $100.14.
Does the left rear quarter panel molding have a bolt?
There are 7 or 8 clips and one bolt which is
at the lower corder of the door covered by black plastic.
Remove the bolt and carefully pull the molding to unclip it.
This helps alot. Going to be removing my passenger side flare to trim it to fit a tlc80 snorkel kit. Everything seems to line up beside a little bit of the flare. Thanks for the pics for guidance.
Sorry the color didn't match, when I saw your post earlier I was going to ask how well the Duplicolor matched your paint, again sorry to hear the answer!
I do know there're 2 different white paints for the 4th gens, are you sure you know which your's is, or if they indeed sent the correct one?
Yep, my 4Runner color code is "056 Natural White". The Dupli-Color color code is "Natural White (056)"
Doesn't match.
I'm going to try the SEM Products Factory Pack paint which costs like $20 for a spray can (plus I need to spend another $20 for the spray can of 2K clear).
