replacing valve cover gaskets
heard4it
Hello all, new to the forum and to 4runners. I recently traded in my Tacoma for a 2010 4runner w/ 211,000 miles. I changed the spark plugs this week and noticed oil accumulation in several of the spark plug holes. No signs of oil burning or head gasket leakage from what I can tell. I'm led to believe a valve cover gasket and spark plug gasket job is in order. Before diving in and ordering parts, I just wanted to confirm the part numbers I have here are correct. Also, are there any other parts or tools I would need or recommended for this job beyond basic hand tools. Any sealant needed around the valve cover gasket when replacing? Here is the list I have so far (my main point of concern was if the intake manifold gasket was the correct one as there were a few in the parts fiche to select from). I'm also planning to replace the PCV valve as a preventative measure. thanks in advance
11193-70010 x 6 (plug tube seal)
11214-31030 x 1 (valve cover gasket)
11213-0P010 X 1 (valve cover gasket)
17176-31140 x 1 (intake manifold gasket)
Keep in mind that the dual VVT-i 1GR has the VVT oil supply going through the valve cover unlike the single VVT-i so you may need the crush washers for the banjo bolts.
the first 3 part numbers are what were used to replace mine and spark plug o ring seals. I did not require the intake manifold gasket to be replaced so I don't have that part for reference
In addition, 18 sealing washers were used 90210-06013 and I did the camshaft gasket at the same time
camshaft: 11159-0P010 x 4 and 90430-10024 x 2. I had this done at the dealer
Here’s what you need to replace
thanks, do you remember if any sealant was used on the valve cover gaskets?
Talyn
