Resistance numbers for the IAC
T4Rscott
Hi all,
I’ve recently had an issue with high idle, 1000rpms.
I found a post over on Yota Tech that states the resistance value for the IAC should be between 21 and 25 ohms. The reading I got was 19. Is there someone who has a FSM that can tell me what is an acceptable number?
I don’t want to start throwing parts at this.
Thanks,
Scott
On my 2000 fsm I got:
Cold - 17-25 ohms
Hot - 21.5-29.5 ohms
Cold = 14-122f iac coil temp
Hot = 122-212f iac coil temp
Hi all,
Thanks,
Scott
I couldn't find the iac resistance values on my 3rd Gen fsm but I had a document for a 5vz-fe 2000 tacoma. hope it helps
Well, after putting in about an hour of testing voltage and resistance, I believe I found my issue.
When I first took my resistance cold, it registered 19.3 ohms. When I took it again hot, it came up 0.00 on my meter. I removed the coil from the valve itself and it moved freely. At that point I checked resistance again, it it was still 0.00.
Now to find a deal on an IAC.........
Thanks to all!
REE
