Reverse Lights
So I replaced my reverse lights as shown in the link below. These lights are no better, maybe even worse than the stock lights. This thread is several years old, so maybe those lights are out of date. I did a google search & these are the most recent that came up. Does anyone have a better option, that doesn't cost an arm & a leg?
LED Reverse Lights for 5th Gen 4Runner, Reverse Lights LED Swap
Diode Dynamics Tail as Turn module is $50. Then just purchase the LED of your choice, doesn't have to be through DD.
Thanks NW.OH.T4R, I should have specified better. All I want to do is switch out the bulbs. Doesn't even need to be LED.
Cut and paste this into Amazon. They are awesome for $14....
JDM ASTAR Extremely Bright 2000 Lumens 360-Degree Shine 921 912 90-EX Chipsets LED Bulbs For Backup Reverse Lights, Xenon White
I put these JDM ASTAR 921 in for $14, they're plenty bright enough!
Reverse lights
which ones do you have?
Went with these. Mounted underneath tucked away. Tap the hitch for power and reverse trigger. Black and yellow, grabbed a ground in the hatch and ran relays to switches on the dash. Auto on with reverse/off/ on at will, helps with tailgaters
Does anybody have the Vleds for $70 a pair? If so comments and maybe
pictures from outside and the dash cam.
Thank you
It looks like you re-mounted your trailer plug. Am I right? I've thought about moving mine. Tucked back up is nice and out of the way, but it sure sucks when you want to plug into it.
If you did do it, what did you do to move it regarding wiring and mount?
Do your bulbs have LEDs all around the bulb or just on 2 sides? Mine were only up & down and I had to rotate them so the LEDs were facing right & left. Made the visibility better by casting out the light in the proper directions. Hope that makes sense.
I was thinking of putting rear-facing light pods. They would be way brighter than the stock lights, even if I used LED bulbs instead.
Yeah I removed the stock plug and bracket. couldn't find anywhere to aline both(centered) right and left side without getting rid of it. I bought this on amazon and screwed it to the "L" bracket holding up the light. Still tucked away but easier to plug into. They also sell flush mount if your brave enough to cut into the bumper. I've seen a runner in this forum that did it
https://www.amazon.com/gp/product/B0002RNS8C/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
354846d1582163069-reverse-lights-20190818_141233-jpg
Edit, here's the guy that flush mounted them
Post 1518
Post your 5th Gen Super White T4r photo
351414d1578098060-post-your-5th-gen-super-white-t4r-photo-2019-12-28-11-39-02-jpg
