Review of OME 880/906 Lift for 3rd Gen 4Runner
Thanks for making this thread too, it's exactly the info/pics I needed. I just replaced my clutch so I'm finally caught up on maintenance and now I'm planning out my lift.
I replaced the rear shocks with Bilstein 5100s about a month ago after I broke a shock while offroading. There's a lot less bounce in the rear with new shocks but they still sag like crazy since the original coils are there. I'm going to go with 906 springs in the rear -- the instructions for the Bilstein 5100's said the shocks are optimized for 3rd gen 4runners with a 2" lift, so those springs should be perfect.
For the front shocks, I'll do another set of Bilstein 5100s. I've heard mixed things about Bilstein 5100s but it's hard to figure out which version people are talking about and with how much lift (lots of older comments are about the Tundra version, whereas I'm buying the 4Runner-specific version). I was thinking of doing OEM tall coils up front since I like how they are driver/passenger side specific, but after pricing it out I think I'll save myself $100+ and go with the OME 880s, like you did.
How much are you sagging? Do you have fender/hub measurements?
I'm looking at suspension options for my 99 with 235k mi. I'm sitting 20.5 driver side, 21 passenger side with bouncy Rancho shocks/struts and oem 99 coils. Maybe I can get away with 4600's and keep my coils?
I was thinking 4runner 5100's 880/906 combo but I don't want the reported harshness unloaded.
I have 4600's on my 4Runner... (have for ~10 years). They are comfortable and work well with a stock setup.
-Charlie
When I bought my 2000 Toyota 4Runner, the shocks definitely needed replacing (160k miles, probably still original shocks!). So I decided to replace the springs while at it too. I wanted a small lift, <2". I thought about buying the Toyota '99 coils for a 1" lift, but OME was cheaper so might as well go close to 2"
Parts ordered:
  • OME 880 Front Springs
  • OME 906 Rear Springs
  • OME 90004 Front Shocks
  • OME 60028 Rear Shocks
  • OME 95PF5 Front Trim Packer (wasn't installed)
  • OME 80PF10 Rear Trim Packer (wasn't installed) (but 3 years hindsight says I should have put them in)
I did not get a diff drop or the stainless steel brake line. I got KYB strut mounts since might as well replace the strut mounts while in there.
Pics after install
I didn't get any good before pictures, so all I have is after. Here's the two side pictures...
(whoops hosting for these photos went down, I'll see if I can find them some time)
And a pic of the vehicle fully loaded with camping gear for 5 people and petrified wood...
Measurements
I measured the height from the ground to the edge of the black trim around the wheel wells. Truck was unloaded other than the stock hitch, spare tire, and just over half a tank of gas. Measurements taken about 100 miles after install. These pics and measurements are with the stock 265/70r16 tires (31", or precisely something like 30.6").
  • Front driver: 35 3/4"
  • Front passenger: 35 3/4"
  • Rear driver: 36 3/4"
  • Rear passenger: 36 1/2"
The driver side in the rear was actually a little HIGHER!
So I originally thought that my shop installed both the front and rear driver side trim packers, but apparently they didn't... I looked in the box with my old springs, and there were the trim packers in their original bag!
(Old info): Thus, my advice is: do NOT use the trim packers! The measurements above don't have the trim packers, and clearly the truck sits perfectly! With a full tank of gas, it seems like the driver side might be a bit lower (I quickly measured it again). That's as perfect as you can get.
After like 5,000 miles, the truck is still sitting wonderfully level. Trim packers definitely not needed.
CORRECTION 7/2017: Trim packers NEEDED! 3 years later, my driver side is lower. I started noticing it being lower after 1 or 2 years. I haven't tried putting them in yet though.
Comfort of ride
I was pleasantly surprised by the ride quality. I was afraid it'd be too rough after hearing some people talk about the suspension. It's probably not as soft as stock Toyota springs and shocks (never got to experience a good stock suspension), but it isn't unpleasant or awful either! And that's coming from someone who always drove cars before this, so I still am more used to things riding like a car than "riding like a truck".
The only harsh experience about the suspension is when going a bit faster over some speedbumps... it feels like the rear jumps up off the ground when hitting the speedbump! Maybe if I went even faster (I was only going about 10 mph tops) it would actually absorb the bump.
I was wondering how Bilstein's would feel instead of the OME Nitrocharger shocks. But I'm quite happy with the full OME package.
Off road ride
I still haven't had a chance to go off roading with the new suspension. I've hopped a few curbs just to see how it feels, and it feels much more solid and strong. I'll try to update this after I go wheeling!
Update: OFF ROADING!
I finally did some wheeling. There's definitely different types of off road, so I'll break it down by the type...
Washboard dirt roads
If you're on a dirt road with tons of washboard but otherwise no bumps, the OME setup is quite rough. It doesn't do well absorbing washboard. When I rode in my friend's stock Ford Explorer, I was like "Whoa, your vehicle actually absorbs washboard" haha.
Dirt roads with potholes, big bumps
As long as you go fast, the OME suspension loves absorbing big bumps/potholes. Go slow, and it won't absorb. I like to go faster on dirt roads (where it's safe and can see ahead for oncoming cars), so the setup works well. I love that you won't feel any extra rebound when going over big bumps, it controls the bump perfectly.
Rock crawling
The OME suspension feels perfectly controlled on slower low-range obstacles. It handles drops off rocks perfectly, feels sturdy, etc. Definite improvement over stock. The extra lift has definitely helped clear some obstacles. I scratch the hitch less, and feel less worried about scratching the underside.
19 posts since 2013 but you keep this thread updated, good job OP! :hail:
Thanks for the review! I picked up a full OME used setup (880/906) with shocks (90004 and 60073 I believe) for only $100!! Installing it soon along with poly swaybar bushings F/R
Crookedcat
