Just kind of following up here on this. The last time I lubed the driveshaft was at 20700. At that time I lubed all 6 fittings. I put 2-3 pumps into the u-joint fitting just till I could hear the grease starting to express and on the slip joint fittings enough to just observe expansion of the joint. At the 30,000 mile oil change the clunking had not returned. It was not until around 32-33K that I started to notice the clunk again.
Here at 36400 I changed the oil and greased up the shaft again. Once again it only took 1-3 pumps to fully lube the U-joints. On the front slip joint it took 21 pumps and on the rear slip joint 24 pumps to just observe a very slight expansion of the joint.
I recently spoke with another Toyota mechanic about it and he too cautioned me about not wanting to put too much grease in the front slip joint, qualitatively describing the amount as a little more than what he'd put in the U-joints. Guidance from the local Toyota service department of just to the point of expansion was the protocol that was bring followed. I think that this gives us a framework as to an approriate range. Moreover,I think that based on the discussion, the procedure that I'm following is about as aggressive as one should get.
That said, anecdotally I can tell you that the lower amounts do not keep clunk at bay nearly as long as taking it to expasion and my inclination is towards the aggressive regiment.
And probably not for any better reason than, I don't like the clunk.
A more resonable man would probably do well with a proportion of 1-2 pumps in the u-joints, 6-7 in the front slip joint and 7-8 in the rear slip joint with every oil change.
Still absolutely loving this vehicle.
