Revtec spacer lift to a OME med duty front set up?
Colemanfu
My front is starting to sag just a bit so I ordered a set of OME med duty front springs and shocks with the 13mm spacer? I think? Just curious if I can expect more lift with OME? I already run the OME springs out back with about an in of spacer (that I cut down) so now it will all match. I would like the front a bit taller than with the spacer lift so hope this set up does the trick. What ya think?
Should get it next Tue - going to be a long weekend waiting. I plan on doing the install myself - just need to borrow the spring compressor. Any tips to the front install?
